In the Slow Lane
930 Rebuild (street only)
After much thought, it is time for some upgrades for my 79 930. I am a regular reader of this forum, but this is my first post. I am planning to upgrade the head studs, tensioners, exhaust, cams, clutch/pressure plate, and turbo. The case will be split for a complete rebuild etal. I value the advice of fellow Pelicans that have gone before me. The car is a low mileage stock 79 930 that I drive almost everyday. No track or racing, just enjoyable street driving in the 2500-5000 rpm range. I am seeking some performance gain, but mostly peace of mind and day-to-day reliability. I would like to keep the car as "original" as possible. I appreciate your suggestions.
Old 08-28-2006, 10:28 AM
adomakin's Avatar
Hi, congats on finding this place-you've just saved yourself a fortune and spent a fortune in one go! So your engine is a low miler thats not thrashed and in good condition? If there are no serious issues (i.e. broken head studs/low oil press/lots of smoke) and you get some good leakdown figs then I would advise some simple bolt ons to start with- straight forward stuff that will ease you into the vast ocean that is modifying 930 engines. you can expect some real good power gains and a lower spool up from things such as headers (B&B/GHL) K27 high flow turbo, bigger intercooler etc. all of which you could call 'weekend mods' and don't reqiure any serious modifications to install. If you want more then you could start thinking about pulling the engine out and tearing it down but if i were in your shoes I would go with bolt ons and enjoy it sooner! hope this helps
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 08-28-2006, 02:12 PM
In the Slow Lane
Adomakin, thanks. I have selected a B & B header/muffler exhaust system. I am most concerned about the cams and turbo upgrades? I had not planned to change the intercooler as I will be running 1.0 bar, but if an upgraded intercooler will improve engine life and reliability, I would consider it. Any advice is much appreciated?
Old 08-29-2006, 08:37 AM
The intercooler is a must do a search, there are toons of options out there at varied prices.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 08-29-2006, 07:22 PM
Ken911's Avatar
and the stock intercooler is a piece of crap. At air temps above 80F it becomes heat soaked and actually adds heat to the turbo discharge.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 08-29-2006, 08:58 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
intercooler is a relatively cheap way to add some power and reliability. on top of that you can put a water fogger, think windshield wiper bottle and nozzles spraying on the intercoolar. say what you will but it helps when temps start to get out of hand, not a long term cure but for short stints it is great, my cousin runs one on his supra, one of the fastest on the west coast to great effect.
74 911s neverending story. two feet and a jetta for now.
Old 08-30-2006, 12:25 AM
forget the water fogger, it is complicated and really a bandaid fix, what you need is a properly sized intercooler for you application, there are a litany of options out there depending on what you want to spend and the quality you expect.
Lincoln Phillip
Old 08-30-2006, 07:20 AM
Wo ist die Rennstrecke?
DonE's Avatar
Hmmm... Lots of rally teams would disagree with you.
In fact, my EFI software has a provision for water-cooling the IC by boost, throttle position or RPM.
Old 08-30-2006, 07:47 PM
In the Slow Lane
What about cams (SC vs. SC 330 vs. 964) and turbo (K27 7200 vs. K27 S) given my desire for more low/mid range power. As I mentioned before, I have chosen a B and B header exhaust, does it make sense to go with a long neck B and B intercooler to match? Any experience with Blownsix intercoolers?
Old 08-31-2006, 07:10 AM
beepbeep's Avatar
SC cams, bigger intercooler and modern turbo will go far. Porsche crowd defaults to KKK K27 most of times, being conservative and all. But there are better turbochargers nowadays. Garrett GT35BB is very nice piece of equipment and more-or-less state of the art when it comes to reasonably priced road stuff.
Thank you for your time,
Old 08-31-2006, 09:45 AM
Crotchety Old Bastard
RarlyL8's Avatar
The Blownsix intercooler can be had for a good price right now because they are not "out there" yet. A buddy just bought one and should install it soon.
Beep - so if we don't have twin monster turbos hangin' out the back and an intercooler that won't fit within the confines of normal bodywork we are conservative? HA!
Old 08-31-2006, 10:10 AM
Ken911's Avatar
the water fogger doesn't work near as well as direct methanol injection. which costs about the same and uses most of the same parts.
2019 Silverado 6.2L
Old 08-31-2006, 12:43 PM
beepbeep's Avatar
Hehe...no, but you must confess that confess that majority of 930 afficionados still buy those K27's for some quite hefty prices, despite being old design.
Old 09-01-2006, 08:54 AM
In the Slow Lane
There are many versions of the K27 turbo available - given the new SC cams, B & B headers/exhaust and the desire for much better low/mid range performance - any suggestions on the K27?
Old 09-03-2006, 06:56 AM
DonE's Avatar
The stock K27 is not a high performance piece. Even though you state you will not go over 5000 rpm (first time I've ever heard that...), you should upgrade to something more modern and flexible (will accomodate your future mods). If you are a DIY kinda guy, look at the Garrett's. If you are looking for a bolt-on solution, look to Kevin at www.ultimatemotorwerks.com. Bolt-on however, comes at a price.
Old 09-03-2006, 07:13 PM
In the Slow Lane
DonE, sorry for the confusion. I definitely go over 5000 rpm.... I just want my useful power band to where the bulk of my driving is. That would be from 2500 - 5000 rpm give or take a little. My preference for a turbo upgrade is a DIY bolt-on solution.
Old 09-04-2006, 06:01 AM
In the Slow Lane
Any thoughts on using a stainless steel head gasket on a 79 930 engine?
Old 09-08-2006, 01:27 PM
WydRyd's Avatar
Yes, you can use the C2T 3.3L turbo head gaskets in your engine for even better sealing at higher boost levels (< 1.4bar). If you plan to run any higher boost levels, then you need to look at Flame Rings (Nerosist).
I run C2T head gaskets in my motor, as recommended by Protomotive
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-05-2006, 10:28 PM
Send a message via AIM to Chuck Jones
Pushing 930: I'm chasing the same subject you are...and rather than put the board thru the same questions, I'd like to hear what you've decided and why...but I can't email you privately because you have indicated you don't want to receive email. If you could contact me at fishoncj@aol.com I'd like to discuss what options you are considering, and what you've found so far. Regards, Chuck
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 10-18-2006, 06:22 PM
BReyes's Avatar
Welcome.
Here is one source: www.goingsuperfast.com (I haven't used these guys (yet-don't know if I will) but found the information helpful while researching turbo upgrades).
It sounds like you are talking about a top end rebuild with while you are there performance upgrades. What has your machinst/builder advised?
Do you have compression/leakdown numbers to justify tearing into it? Is it using too much (>1 qt/1000 mi)oil. Is it leaking oil?. Don't forget the oil lines.
Seems like you take it easy, yet are nearing the the slippery slope.
Have fun. Be safe. And good luck!
Regards,
Bernard
Old 10-18-2006, 09:46 PM
