Remove air injectors or not?
Hi There,
I am rebuilding my 1985 930 Turbo and I am considering not refitting the air injectors that fit in the exhaust ports back when I rebuild.
For what its worth I don't believe they are necessary and also I ended up having to cut a pipe to one of the injectors in order to get it off (its a long nasty story).
Does anybody have any opinions on this one or any good advice?
Thanks in advance
Steve in the sunny UK :-)
Old 07-04-2006, 12:58 PM
I'd only refit them if I needed to pass a smog inspection. Be sure to put some kind of plug in the holes. These are available in several places and are not tapered threads.
-Andy
Old 07-04-2006, 02:20 PM
Thanks for the help - any advice on where to get a plug?
Regards
Old 07-04-2006, 02:33 PM
Try not, Do or Do not
Henry Schmidt's Avatar
There is no way I would run air injection on an engine that was smog exempt. It creates heat and heat is bad.
No smog test= no smog equipment.
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-04-2006, 04:08 PM
Hello, Steve.
Its an odd thread..
I'd weld the injectors and use them to block the holes..works fine.
Kind regards
Old 07-04-2006, 04:31 PM
Ken911's Avatar
throw that smog crap in the trash then plug the holes. you should still be able to pass the smog test without it. the plugs are easy to come by just take one of the air injectors to you local nut and bolt store and they should have socket (allen wrench) plugs. i did that here they were about 20 cents a piece
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 07-04-2006, 04:46 PM
89turbocabmike's Avatar
Air injectors make great potential FOD (foreign object damage) for a turbo as I've found out in the past. My turbo passes strict California standards with just the Cat in place. If I remember correctly the thread pitch on those is 10-1.0 . Pelican sells them.
Old 07-04-2006, 10:10 PM
look for hex head 914 rear caliper plugs on pelican.
206 637 4071
Old 07-04-2006, 11:22 PM
Porschephd's Avatar
We also have the special plugs that are thin and fir right up in there
Stephen
94 3.6Turbo 6-speed AWD
Old 07-07-2006, 01:19 PM
Thanks for all the advice I have found a supplier in the UK for these plugs and my air injectors will be history!
Many thanks for the advice I appreciate it.
Regards
Old 07-08-2006, 04:05 AM
