flatsixcrazy's Avatar
Bead blasted Mahle's 3.2L cylinders. What do you think?.
Used 3.2 Carrera P&C's
Hey Guys,
I am thinking about buying the set of 3.2L mahle cylinders in the above link and wondering if bead blasting the outside of Mahle's cylinders is a bad thing?. Wayne's book did not recommend the cylinders to be blasted, or did he mean the interior of the cylinders?. The seller said that the inside of the cylinders are fine. Can anything bad comes from bead blasted cylinders?. Thanks for all your help. Andy
Old 08-17-2006, 06:48 AM
As long as they didn't do the inside they should be fine, we used to bead blast cylinders from air cooled airplane engines to clean them. Bead blasting is a lot less erosive (sic?) than sand blasting.
Robert
Currently Porsche less (but the wife has 2)
Old 08-17-2006, 07:30 AM
agreed.
206 637 4071
Old 08-17-2006, 08:08 AM
Roslin's Avatar
What id bead blasting ( sorry i am Danish :-) is it with glass, plastic or som very fine ceramic powder ??
Roslin
Porsche 911 SC 3.0
Old 08-17-2006, 01:10 PM
I bead blasted mine but I first taped up the openings very well, they came out really nice. I also modified my hone to use fine scotch brite pads to clean the inside of the barrels. I did it with a bit of oil but most recommend to use hot water and soap instead.
Good Luck,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 08-17-2006, 04:18 PM
Thanks guys. The P&Cs are on their way. Andy
Old 08-17-2006, 04:43 PM
Roslin:
The reference here is to glass bead blasting,......
We use soda blasting equipment (same as the aircraft industry) since it leaves a natural finish and cannot peen or damage metal in any way. This ensures that the Nikasil bore won't get accidently damaged.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-17-2006, 05:07 PM
this may not be an issue with just doing the outside of the cylinders... but you can read in a number of places to be sure, 110% sure, that for any reason glass beads not get inside the engine... to me this means not even letting glass beaded parts or material on the property while an engine rebuild is in progress... if it was me I would use something else e.g. walnut shells or just chemicals... that's my 2 cents.
Sold: 1989 3.2 coupe, 112k miles
Old 08-19-2006, 07:21 AM
Roslin's Avatar
Thanks to all of you for the replay !
Roslin
Porsche 911 SC 3.0
Old 08-21-2006, 01:13 PM
Grady Clay's Avatar
Roslin,
You are getting good advice here.
I agree that most important is to keep your rebuild absolutely clean. This is particularly true of cleaning media. Processes that don’t have the possibility of contamination are clearly best.
Some techniques (sand or glass) have the advantage of roughening the surfaces for better heat transfer. At the same time, extreme care must be taken to prevent any media inside the engine.
There are different processes for different parts of the engine. There are even different processes for different surfaces of the same part. Masking and other protective measures are extremely important. The goal is to have the surface appropriate for the use. That can be cooling, friction, beauty and more.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-23-2006, 07:49 PM
