Another question: Which years Cup engine is the most liked? |
Gee, Pete, you sure seem to know a lot about the GT3 electrics.
JPIII Early Boxster |
In terms of the year, most people argue either for an early or late motor, with the mid years seemingly slightly less loved. Early ('00-'02, I think) ran lower 11.5:1 compression, solid lifter cams, and lower revs. Thus they are easier to run on pump gas, they generally have lower oil consumption, and time between rebuild *might* be longer. The middle motors switched to longer rods, different rod-end bearings and hyd. lifter cams; power and oil consumption went up- these are generally not as favored. The '05s-'07s had some small fixes, and power was uprated to 400. I believe they are also slightly lighter than the early motors, though compression and oil consumption are up slightly. I understand that the '08 motor dropped the VRam style 2 chamber intake manifold and bumped compression up further to 12.5:1, and finally got a decent exhaust manifold. This should make it lighter still, and it's rated at 420 hp, so it's probably the one to have but it's expensive... I'm told the '00-'02s generally dyno in the 335-340 rwhp range, while the late ~'06s dyno in the 365-370 rwhp range. Not sure what the '08s dyno at, but I'd guess ~385. All pre-'08 cars have a poor exhaust manifold design- ~20+ hp can be found by fitting a proper equal length manifold. All of this info comes as word of mouth- I haven't found the big spec book that lists all of this stuff... -Pete |
What was wrong with the rod bearings of the middle motors? Could hydraulic lifter cams be reverted back to solid type? Quote:
If you want to go that far, however, you can just get an early grand-am spec motor and run it on good gas. The later ones had 2 ring pistons (vs 3 in the cup motors) that wear faster, but the early ones were quite similar to the cups. You can extend the TBO by cutting revs a little if you want. PM me if you want motors/ prices- I can point you to some. -Pete |
