CBRacerX's Avatar
Angry Wanted: 964 #8 Dowel Pin (or how did I lose that!)
Don't ask me how, but I had the pin set aside and used in my last few test fits of the crank - but when I am _all_ ready to seal the case it goes missing! Arrgghhh!!
So I am begging - does anyone have one? If not, special order from PCNA I suppose
Thanks,
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 07-10-2006, 07:31 PM
len911's Avatar
If you are referring to the bearing positioning pin on the #8 bearing, I have succesfully used a screw of the right diameter and cut it to size. Engine still running and it did not care that it was not a real Porsche part. Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 07-11-2006, 05:35 AM
tops911's Avatar
I'm no expert, but I think I read where John Walker said to use a drill bit. Find the right size to fit the hole and then cut the shank end to the correct length. I hope this helps.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 07-12-2006, 07:17 AM
CBRacerX's Avatar
Thanks guys, both good suggestions. Part was .45 ($4 to ship!) and I will have in the next few days...
Chris
Old 07-12-2006, 07:22 AM
Please don't forget to check every nook and cranny for the wayward piece. I would hate to hear that it reappeared inside your case after you complete the rebuild. A .45 cent part can certainly do thousands in damage. Good luck and keep us posted.
Art
74 914 2.0
71 911 2.7 MFI RS clone
Old 07-12-2006, 07:44 AM
