odd question...rear engine tin ?
I recently blasted my engine tin, and I need to know about a couple of the fastenters. When looking at the flywheel side, to the right (below the reference sensors), there are two holes for attaching the tin....I think those two holes utlize a hex bolt (I think they're called pan-hard screws). Is the tin attached with little hex bolts, or is it by the traditional bolt/washer....? Sorry if it seems like an odd question, but I've had a hard time aligning the tin using the traditional bolt/washer....? Thanks...
As I remember there were 2 allen head screws somewhere in that area? or as the katalog calls them (pan-head screws)
yeah the 3.6 has the allen head screws - presumably because there isn't enough clearance to put the standard hex-head bolts in.
That is was I thought as well...thanks for the responses...I'll try it again this evening.
| All times are GMT -8. The time now is 04:24 PM. |
