johncmng's Avatar
Angry Removing Head temp sensor
Does anyone know what tools you need to remove the head temp sensor (I think it's the head temp sensor?)on a 85 Carrera? I cannot fit a wrench into the tight space to turn the nut.
Old 07-14-2006, 11:03 PM
Jeff Alton's Avatar
You need to cut a slot into a socket or or grind down a box end wrench to clear it........ (14mm IIRC)
Cheers
www.turn3autosport.com
Old 07-14-2006, 11:07 PM
johncmng's Avatar
Is that the only way!? It a shame to destroy a good wrench.
Old 07-14-2006, 11:12 PM
89turbocabmike's Avatar
You don't have to use a good wrench.
Old 07-14-2006, 11:26 PM
If you are planning to install a new sensor, just cut the wires and use a socket to remove the old one.
Goop the threads of the new one with antiseize and use a metric adjustable to snug it up.
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 07-16-2006, 08:39 PM
3.4 Bigger is better
88-diamondblue's Avatar
When I replaced mine I was able to use a Craftsman flare nut wrench. Fit perfectly and the Snap-on was too big to fit.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 07-16-2006, 10:06 PM
Snap on makes a slotted socket but it costs than most people are willing to pay.
Lisle tool makes a bunch of slotted sockets for removing oxygen sensors, and I think you can get slotted sockets from Napa auto.
Old 07-19-2006, 12:57 PM
