engine # *6392956 someone?
This is in a '76S
My dads old car. Once a bad leaker but now dry??? |
Looks like a '69S.
... or a '79 3.0 SC - Porsche in their wisdom used this same series of engine numbers for both years !
Installed in a 76 car and no oil leaks I'd guess 1979 3.0.
Is it mag or aluminum? We could use the designation number (930/??) to be certain. This number is located on the engine case on the right side of the fan housing. Case casting number will also tell us which one you have. |
That number looks like 930-OS
Does that make it magnesium or aluminum? Still a '79 3.0L? |
79 911 SC 3.0. Aluminum
This is a very nice up grade for a mid 70s 911. |
More than likely 930/03 - that would concur with it being a '79 SC engine (aluminium crankcases).
930/05 is a Japanese-spec '79 SC engine (serial number would be 619XXXX). 930/06 is a California-spec version with serial number in the form: 659XXXX |
YOO DA Men!
laquer thinner/toothbrush....it is a "3" Thanks so much for your help. |
I'm a huge fan of 1974-77 cars with an upgraded engine. These cars are so neglected and unwanted by the Porsche community for their 2.7 engine problems, that you rarely see too many these days. Installing a 3.0 solves 95% of the engine problems (replace head studs and install Carrera chain tensioners while you're at it), and really makes these narrow body cars sought after.
-Wayne |
| All times are GMT -8. The time now is 03:32 AM. |
