engine # *6392956 someone?
This is in a '76S
My dads old car. Once a bad leaker but now dry??? |
Old Member
Looks like a '69S.
Clifton Brown https://www.mancalamarketing.com |
... or a '79 3.0 SC - Porsche in their wisdom used this same series of engine numbers for both years !
Andy M&W 904 ... now gone GT-style 356C ... also gone |
Try not, Do or Do not
Installed in a 76 car and no oil leaks I'd guess 1979 3.0.
Is it mag or aluminum? We could use the designation number (930/??) to be certain. This number is located on the engine case on the right side of the fan housing. Case casting number will also tell us which one you have.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
That number looks like 930-OS
Does that make it magnesium or aluminum? Still a '79 3.0L? |
79 911 SC 3.0. Aluminum
This is a very nice up grade for a mid 70s 911.
More than likely 930/03 - that would concur with it being a '79 SC engine (aluminium crankcases).
930/05 is a Japanese-spec '79 SC engine (serial number would be 619XXXX). 930/06 is a California-spec version with serial number in the form: 659XXXX
YOO DA Men!
laquer thinner/toothbrush....it is a "3" Thanks so much for your help. |
Author of "101 Projects"
I'm a huge fan of 1974-77 cars with an upgraded engine. These cars are so neglected and unwanted by the Porsche community for their 2.7 engine problems, that you rarely see too many these days. Installing a 3.0 solves 95% of the engine problems (replace head studs and install Carrera chain tensioners while you're at it), and really makes these narrow body cars sought after.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
