johncmng's Avatar
Wax or Crud underneath the car???
As I started to remove the motor from the car, I notice there were a coating of wax of some sort underneath the entire car and all over the tranny. Anybody know what this stuff is? Should I take it off? If so, what should I use to clean it? Will a power washer do?
85 Carrera
John
Old 07-21-2006, 10:22 AM
PPilot's Avatar
Sounds like somebody sprayed undercoating of some kind ..removal with an appropriate solvent will take a little research and careful experimentation...I would just leave it, probably put on in a northern clime to protect from salt!!!
1984 RoW Cabriolet (needed me-followed me home)
Old 07-21-2006, 05:01 PM
Re: Wax or Crud underneath the car???
The waxy substance is cosmoline, a rust preventative corrosion inhibitor sprayed on at the factory for the shipment across the Atlantic. It looks crappy but it works and it doesn't hurt anything.
Old 07-21-2006, 09:22 PM
cosmoline
...And the cosmoline helps protect magnesium parts (like transmissions and some engine cases) from corrosion.
Old 07-22-2006, 08:38 AM
19 years and 17k posts...
azasadny's Avatar
Mine had dirt/oil combination that looked like a "wax" or coating of some kind. A brass-bristle brush, Simple Green and a power washer cleaned it all up but made a mess of me and my clothes! Wear goggles and protective clothing!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-23-2006, 06:07 PM
Maybe this helps
http://www.surplusrifle.com/shooting/cosmoline/index.asp
Old 07-25-2006, 12:13 PM
