-   -   9.8 or 10.1? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/294214-9-8-10-1-a.html)
Scott Clarke 07-19-2006 08:44 AM
9.8 or 10.1?
I need to decide my deck height. I measured cylinder head and piston dome volumes last night. Motor is short stroke 2.5, JE pistons, 2.2E heads cut for 90mm cylinders, cylinders are reconditioned, and had top surface machined, std crank and rods. Head volume is 68.4 CC. With a deck height of 1.5mm I'd be at 10.1:1, and with 1.75mm I would get 9.8:1. It seems to me that 9.8:1 is the way to go for pump gas/single plug with E cams. Anyone agree or disagree?
Thanks,
-Scott
kenikh 07-19-2006 08:49 AM
Shouldn't deck height be 1mm (ideally)? I thought that higher deck heights are just as bad for detonation as higher CR can be.
Scott Clarke 07-19-2006 08:56 AM
Increasing the deck height dimension is actually lowering the piston relative to the head, reducing the CR. I believe Wayne recommends a range of 1.5mm to 1.75mm. I don't have the book in front of me, so I can't verify. (edit 7/21: Wayne's book states that Walt Watson recommends 1.25 mm to 1.5mm for "stock" engines). Machining the head for the bigger cylinders results in a reduction of the combustion chamber volume, necessitating a little bigger deck height number (thicker shims). So, I think my numbers are right were they should be.
-Scott
Steve@Rennsport 07-19-2006 09:52 AM
Yessir, that is basically correct,....:)
Too much deck height promotes detonation as well as too much compression. 1.0mm is correct and 1.5 to 1.75 is too much.
davidppp 07-19-2006 09:58 AM
Hello Steve.
Have you actually tried running much less than 40 thou?
I'm intrigued to see what others have found..I have not yet built a real hot engine with much less than this..but have made a road engine with 25 which lived happily..so I'm tempted to try on a race motor..probably with 30 thou..
What do you think?
Kind regards
Scott Clarke 07-19-2006 10:09 AM
So, my choices are 10.1:1 (perhaps a little high for CR) and a deck height of 1.75mm (large enough to perhaps promote detonation). Which is a better choice?
Thanks for all of your help!
-Scott
ChrisBennet 07-19-2006 10:32 AM
-Scott
You may also have the option of machining the pistons.
A little off the top...
http://forums.pelicanparts.com/uploa...1153330186.jpg
Before and After
http://forums.pelicanparts.com/uploa...1153330207.jpg
-Chris
Scott Clarke 07-19-2006 10:47 AM
I have assumed that 9.8:1 is the practical max CR for pump gas/single plug. Is this assumption correct?
kenikh 07-19-2006 10:51 AM
It your piston diameter, I'd already say you are riding the edge at 9.8:1.
Steve@Rennsport 07-19-2006 12:00 PM
Good job, Chris.
Lowering the dome heights also promotes improved flame travel which is something single-plug motors desperately need, especially at those CR's.
David:
Running much less than .040 results in the pistons striking the heads at the edges. It all depends on the piston crown design and what your piston-to-valve clearances are.
Scott Clarke 07-19-2006 12:53 PM
It looks like I need to remeasure my volumes in order to insure that my data is correct, and think about having some material machined off the top of the pistons. I appreciate all of your responses.
-Scott
davidppp 07-20-2006 08:02 AM
Hello, Scott.
Defintley helps IMHO to take the peak off the piston between the valve pockets.
To keep the CR up I do this like a ditch on 2L's..looks horrid!
The effective and tolerable CR will vary markedly with the cam overlap as I'm sure you know...big cams enable much higher CR's..
IMHO a most important variable for tolerable CR is charge , chamber, and especially exh valve temperature..so the ambient really makes a huge difference.
One of the little secrets of the aircooled motor is the use of inlet charge to cool the exhaust valve. at WOT.hence plenty of charge loss in the exhaust..I've wondered about an afterburner..
Kind regards
Scott Clarke 07-20-2006 06:03 PM
David-
Given the E cams, it seems like I should hold the CR to 9.8 at most. I re-measured volumes last night, and found that I can not obtain repeatable results. I will refine my measurement techniques before I decide what to do.
-Scott
Scott Clarke 08-04-2006 12:41 PM
Update:
I refined my measuring techniques and found that matters were worse that I originally imagined. With 1mm deck height, the pistons supplied would result in a CR of 10.9:1! The pistons were purchased form EBS (prior to Pelican carrying the product). I returned the pistons to EBS so that they could have a look. Following consultation with JE, they found my calculations and measurements to be accurate. The box the pistons were shipped in had "10.5:1, 2.7" written on it with a sharpie. The spec sheet within had measurements that matched the pistons, but it is clear that they would result in about 11.5:1 in a 2.7, not 10.5:1. So, taking the time to measure saved my bacon! EBS is machining the pistons to the correct dome volume. They were very responsive and are doing this work at their expense. I should end up with 9.8:1 at a deck height of 1mm. I'll post before and after shots of the pistons when they return.
-Scott
jdm61 08-28-2006 10:27 PM
I have heard this before and yet the Euro Carrera 3.2 has 10.3, single plug and was designed to run on what would be rated 92-93 octane gas.at the maximum. Can you raise the CR as the piston diameter gets larger? pardon what may be a dumb question, but i am new here......lol
ChrisBennet 08-29-2006 05:27 AM
The factory compression numbers are higher than what you'd get if you actually measure them so you can't use them as a comparison. The Euro 10.3:1 pistons probably measure closer to 9.8:1. (I haven't measured a Euro setup.)
Compression ratio is varied by changing the piston dome volume. Imagine if you made a piston dome that filled the combustion chamber so there was no room in the combustion chamber at all when the piston was at the top of it's stroke. Such a motor would have a compression ratio of infinity:1
(CR = volume at bottom of stroke divided by volume at top of stroke. In our imaginary engine it would be CR = vol at bottom / 0.0)
I wouldn't build a 9.8:1 motor for a street driver these days. The fuel qualities aren't likely to improve. The last motor I did a machined the pistons to 9.5:1 so if he gets a little bad gas and gets stuck in traffic (high temps) no worries.
-Chris
jdm61 08-29-2006 02:58 PM
-Chris
I guess my second question is where are you guys getting all of this bad gas these days? All of the majors here in Florida sell 93 octane Super and I have never had a problem. Even with the outrageous prices, should we Porsche guys really be looking for the "best deal" on gas?
kenikh 08-29-2006 03:10 PM
The best you can get in New Mexico is 90 octane and Cali isn't much better at 91. This is due to emissions; even in Florida, the days of 93 octane are numbered.
jdm61 08-29-2006 05:46 PM
Not unless they ban it nationally. We are a flat and breezy place. No smog or ozone issues to speak of. We used to have emmissions inspections in the major metro areas but they killed those at least 6 years ago. Why do you think we never have to hide our bypass pipes? lol
jadeblaquiere 08-29-2006 07:18 PM
Not to doubt Steve's words... but why does too much deck hight promote detonation?
If I understand things correctly, having a compression ratio too high heats the intake charge to the point that the fuel spontaneously combusts.
I'm just curious as to what the dynamics are for too much clearance (and lower temps) causing the mixture to ignite...
Joe
1986 951
1977 911
ChrisBennet 08-29-2006 07:27 PM
Joe
1986 951
1977 911
Not intuitive is it?
The larger deck height creates a pocket out at the edge of the piston can promote detonation - or at least that's how Steve explained to me once.
-Chris
Steve@Rennsport 08-29-2006 08:13 PM
Joe:
Chris has an excellent memory,...:) :)
You are right about too much compression triggering spontaneous combustion, but there is FAR more to this story. The detonation thresholds of an engine depend on many things such as:
1) Compression ratio
2) Piston crown shape & design
3) Ignition timing
4) Spark plug position
5) Combustion chamber shape: hemi, pent-roof, or wedge
6) Squish band placement & shape
7) Natural turbulence or swirl (or not)
8) Fuel mixture and distribution in the chamber near TDC
9) Cylinder head temps
10) Outside air temps
11) Octane
These are just a few and a thorough discussion of each would fill a book (one day I might do just that).
With regard to the low-swirl found in hemispherical head engines and especially ones with offset plug locations, its critically important to force the air-fuel mixture toward the plugs approaching TDC as cylinder temps are rising. The goal of proper deck height is the prevention of any air/fuel pockets remaining out by the edges of the bores that can ignite BEFORE the plugs do,...:)
Maintaining close (spec) deck heights ensures that the majority of the air/fuel mixture gets squeezed toward and around the plug(s). Too much deck height will leave those pockets of air/fuel and too little deck height permits piston-to-head contact at high RPM.
I shoot for .040 (1mm) in street engines that will run on pump gasolines. For race engines where I'm looking for that last bit of compression ratio, I will reduce that clearance depending on the piston I am using.
Like I said, this subject is fascinating (at least to me) and could fill a book but I hope this helps clarify the issue for you,...:) :)
Analyzing burn patterns on piston crowns and heads for 28+ years gives one an education if one is willing to learn.
kenikh 08-29-2006 08:39 PM
Please write a book. I will buy it!
jadeblaquiere 08-30-2006 07:04 AM
I agree... would make a good book. Thanks for the explanation. Sign me up for the 1st edition!
Until then at least we have the Pelican Parts board... I learn something every day here.
Joe
Grady Clay 09-02-2006 07:23 AM
I am very impressed with your tenacity to get repeatable
CR measurements. This is not as easy as many portray
and there are many places where errors can creep in.
As a final check, I prop the engine so the spark plug hole
is absolutely vertical and measure the CR with the piston
at TDC, the rings and valves sealed with grease and the
head torqued in place. In the CR range of 10:1 to 12:1
you can get accuracy of better than 0.05:1 directly
measured combined volume at TDC.
I have a couple of tools “Of Local Manufacture” to do this.
First is a sparkplug shell modified with a 30 cm piece of
½” drill rod. This allows me to use a level to make sure
the sparkplug is correctly positioned. The other is an
empty sparkplug shell with an O-ring and a calibrated
tube for filling with a burette. Have a calibrated step a
centimeter down and the ID small so you can distinguish
evaporating test fluid from a leak at the rings, valves or
head gasket.
For a measuring fluid I use Stoddard Solvent with some
red ink. I use a high quality glass burette. Use one with
markings etched all the way around. This will help
eliminate parallax and allow good interpolation to 0.10 cc
Steve and I have been in perfect agreement on this for 28
years (I thought it was way over 30).
In this discussion, Steve’s #6) is of particular importance.
The high dome angle at the transition from the flat
perimeter of the piston is particularly critical. The dome
actually “traps” mixture in the pocket formed by the flat
portion below TDC Compression while the piston is still
several mm down. This happens just before TDC
Compression and just after.
Most of the time we concern ourselves with simply the
piston-to-head clearance and try and have it everywhere
equal (and as close as reasonable for the application. In
the above situation the dome “closes off” the area for
gasses to move from (to) this “pocket” faster than the
volume of the “pocket” is reduced (expanded).
Below is an exaggerated diagram where the important
feature is the closing off of the gas path (yellow) while
the “squish” volume is still decreasing (red arrow).
http://forums.pelicanparts.com/uploa...1157206071.jpg
The volume of the “squish area" above the ring will
continue to be reduces with nowhere for the gasses
to go. This is like a second combustion chamber with
a 30:1 CR. The mixture will detonate.
Things go downhill from there.
The “ideal” combustion chamber is almost spherical with
4-5 valves in the head, a central sparkplug, an equally
dished piston and a significant “squish” area around the
perimeter. This forces the gasses back into the combustion
chamber (green arrow).
http://forums.pelicanparts.com/uploa...1157206131.jpg
The problem is that this isn’t conducive to high CR with our
bores, strokes, rod lengths, valve actuation and size and
spark plug(s) placement. Most important is cooling – or
lack of it. This is one of the reasons for the change to
liquid coolants.
The detonation result is classic for Porsche. Detonation
occurs above the compression ring. The aluminum piston
deforms downward and prevents the compression ring
from floating in the grove. Remember it is the gas
pressure behind the ring that provides the sealing force.
Once the ring is no longer able to seal, hot gasses pass
the side of the piston and bad things happen. Typically
the ring brakes up and pieces destroy the piston. In other
cases the piston overheats and expands to seize in the
cylinder. Or both.
What to do?
Almost everything in automotive involves compromise.
With this piston-head situation, you can’t use as much
CR as you might otherwise get. There must be an angle
transition in the head from the deck squish to the
combustion chamber. The piston dome can’t rise as fast
as the angle in the head. The net result is slightly less
CR but not forming a detonation pocket.
http://forums.pelicanparts.com/uploa...1157206175.jpg
With your intended use, you won’t have any issue with
getting high enough CR. In fact you should concentrate
on the best possible combustion chamber, squish and
turbulence. I will still argue for twin plugs.
The “deck” piston-to-head clearance should still be as
little as reasonable given street use and the type piston.
Something slightly more than 1.00 mm seems to be
common. Should it be less than 1.00 mm?
How close do you go?
Best,
Grady
pete917 09-05-2006 06:04 AM
i have a 3.5ltr mahle piston and barrel conversion that I am doing on a eurospec 3.2c. I assume a 0.040" deck height is still required. The heads have been resurfaced and i have had some machining done on the cases to get the bigger bore cylinders located. Its therefore highly likely that each cyclinder will need slightly different shims to get the same deck height across all six.
Is this correct or OK to shim differentyl to get the same heights?
Cheers
ChrisBennet 09-05-2006 06:13 AM
Originally posted by pete917
i have a 3.5ltr mahle piston and barrel conversion that I am doing on a eurospec 3.2c. I assume a 0.040" deck height is still required. The heads have been resurfaced and i have had some machining done on the cases to get the bigger bore cylinders located. Its therefore highly likely that each cylinder will need slightly different shims to get the same deck height across all six.
Is this correct or OK to shim differently to get the same heights?
Cheers
The guy doing the heads should make them identical heights and the guy doing the case should "deck" (make flat and all the same height) the case spigots. The latter operation will change the deck height (see above) and may require a thicker than stock shim height to compensate. In my limited experience, decking the case spigots just made the deck height closer to "ideal" (.0035-.0040") EDIT: Oops, I meant .035-.040", Thanks Grady! with the stock shims.
-Chris
Grady Clay 09-05-2006 07:11 AM
Chris,
Aah, the good ‘ol misplaced decimal point. :eek: Chris, I assume you mean deck (piston-to-head clearance) of 0.035” to 0.040” (~0.9 – 1.0 mm).
Pete, WELCOME to the Forum. SmileWavy You will find a lot of help here. Where are you located? How far along is your project? Details, details.
These clearances are very demanding. What is your experience? What do you have for local resources?
A critical issue in building these is the cam housing must sit on three heads that are at the same height when torqued in place. This prevents warping the cam housing and no longer having a straight bore for the cam. Great care must be taken here.
At the same time you need to have your design deck clearance the same among cylinders and the CR the same among cylinders. This then all needs to be the same as the other bank of cylinders. There is the fit of the chain housing to the cam housing and possibly chain length. Very simple. :D
I recommend you do some serious research using the Search function. A lot has been discussed here and elsewhere but there isn’t a book or single manual. Bruce Anderson’s Porsche 911 Performance Handbook (available from our host) is about as close as you can get. Make yourself a detailed plan. Post it here for review. This not a “try it and see if it works” subject.
The first one of these (74.4x100) we built was about ’78. :cool:
Best,
Grady
pete917 09-05-2006 07:42 AM
Thanks Guys,
Im located in London, UK.
The project has progressed as follows:
base engine: 32.c euro spec;
3.5ltr mahle pistons and barrels;
suffle pinned engine case;
resurfaced engine case;
bore aligned engine case;
polished crankshaft;
conrods capped and honed and balanced;
twin spark heads;
resurfaced heads;
new valve guides;
new valves;
reseated valve seats;
EBS titanium springs and retainers;
ARP rods and bolts;
Resurfaced cam followers;
GTII turbo camshaft profile by Camgrinder;
Apart from being financially ruined :-( so far bottom end has been completely rebuilt, and and initial top end built to test deck heights........
and thats where are I am. Im not personally building, its being done by an engine builder local to me here in the UK.
I am going to have the deck height at .040". A question with regard to tolerance on the deck height in terms of allowable variance between all six. How much tolerance is there before it causes problems with camshaft bore alignment.
Cheers
Pete
Grady Clay 09-05-2006 10:04 AM
Pete,
Looks like a great project. :D
First the usual questions among us “…separated by a common language.”
What is “capped”?
ARP rods and bolts;
Do you mean “ARP rod nuts and bolts”?
OK.
suffle pinned engine case; resurfaced engine case; bore aligned engine case;
How much material was removed when the case was resurfaced? What is the sum of the amount off the mating surfaces and off the cylinder seats? This will give you some idea of the reduction in deck height.
How much was taken off the heads? Enough to have interference between the head and top cylinder fin? Were the heads cut there also for fin clearance?
All these numbers contribute to the narrowing of the engine and the range of easy deck adjustment.
What is the specified Compression Ratio (CR) of the pistons with this stroke? Have you made some actual measurements? How (what techniques)? What results?
What issues are there with this cam and valve-to-piston clearance? What valve cut-outs do these pistons have?
I can’t give you an exact number there because there are too many variables (head mostly). You should measure the deck individually on all three cylinders. Assemble that bank using the cam housing to locate everything (have the cam installed with assembly lube) and to see if there is any cam bind during the head torquing process. If so - STOP. If not, remove the cam & housing and inspect the head-to-cam housing surfaces of the heads with a knife edge. You can spot differences <0.0001” this way.
Additional clearance deck differences in the ‘tenths (0.0001”) range are not of concern. If you are pushing the CR limit, having the CR all the same is more important.
More questions:
What is your planed use?
What car, weight?
What intake?
What exhaust?
What fuel do you plan to use?
Was this a good running engine before? Any prior trama?
How repeatable are your measurements of everything?
With you, your builder and everyone on the Forum, you should be able to have this exactly how you want it. We will be able to see the smile half a world away. :D
Best,
Grady :)
pete917 09-05-2006 10:45 AM
Hi There,
Its been a great [project and has consumed my life for what seems ages:
"Capped" is the resurfacing of the conrod mating surfaces, and then the centre honed out to ensure concentrivity and removal of any ovalness;
I have used ARP for the conrod bolts and nuts, and then also the main engine studs (great product);
our absolutely right, the removal of material from the case halves and heads, although small, has consumed most of the 0.040" deck height, but I will be shimming back to size.
I havent yet measure the CR (next on my list) and will use the method in Bruce or Waynes books. Mahle say that they are designed to retain my euro spec 10.3:1.
The cam profile I decided on i got from Doherty race cams http://www.drcamshafts.com which he has taken my entire spec into consideration. The Mahle pistons come with some deep pockets. Ill be spending some quality time checking P-V clearances in the near future.
I forgot to mention I have also added a Motec M48 Proc CIS to help map everything together.
I had no drama with the ending before other than normal wear and tear.
The intake system is going to be a set of Jenvey Throttle bodies and the exhaust is a custom made equal length stainless steel system from Hayward and Scott in the UK. My exhuast is featured on their website
http://www.haywardandscott.co.uk/case2.asp
everything else i have bought through EBS Racing www.ebsracing.com
The car will be road and track use. Its not been lightened in any way, but I may well do somthing when money permits. This project has a small fortune so far, so things may have to slow done some.
Ill keep you all posted and look forward to all your advice
Pete
CBRacerX 09-05-2006 01:19 PM
Since this has turned into a most informative thread, let me add "my issues" here. I have a set of RSR 3.8 Pistons (which appear to be the 993 version) and have measured my deck height to be 1.3mm using stock 964 heads machined for the larger jugs. Apparently, this deck height is about what they start at. So... Should I be machining the cylinders to get this down to 1.0 mm?
Pics here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/267356-another-3-6-3-8-rebuild-thread.html
Carrera3.5L 09-06-2006 09:11 PM
Pete,
Are your heads still single plug or have you twin-plugged them? I believe that I have the same p/c set that you are using in my engine and I had some compression ratio & suitable deck height issues that needed addressing...
I orginally cc'd my twin-plug heads at 91.8 ml and the cylinders at 71ml. After test fitting a piston/cylinder on the case my deck height was only .5mm with the standard .25mm base gasket. The compression ratio calculated was slightly under 9.2:1. I wasn't happy with this result, so I disassembled the heads on the bench and had them milled .020" to gain back a few tenths of compression, reassembled them and than cc'd again.
Have you cc'd your heads and cylinders yet? I'll give you my numbers just for a comparison. Head volume (twin-plugged remember) after milling .020" was now 88.8 ml. Cylinder volume was 71 ml. With a thicker .5mm base gasket now in place of the .25mm unit I ended up with a .75mm deck height. If I would have stacked a .5mm and .25mm base gasket I would have ended up at 1mm deck height but I personally don't like stacking gaskets if I don't absolutely have to. Measured compression ratio with .75mm deck height was now 9.49:1.
Worked out okay so far (keeping my fingers crossed every time I turn the key)...:)
Ralph
pete917 09-07-2006 02:45 AM
Thanks Ralph. I have cc'd mine yet, but will do so and report back.
I have gone the twin spark route though. I noted on my 3.2 barrels that on the opposite to the spark plug, that the barrel coating had started to wear. With a plug either side it should even things oout and get evenly spread presure.
What other mods have you made to your engine?
Pete
Carrera3.5L 09-07-2006 07:08 AM
Pete
Very minor mods and I am still retaining the Motronic system. Polished the intake ports, Extrude Honed the intake plenums, enlarged throttle body, mild Web Cam 20/21 cam profile, 1 5/8" ceramic coated headers from George Narbel coupled with a Monty street muffler and custom dyno optimized chip from Steve Wong running on poor quality 91 octane "gasoline". We have stringent emissions tests in Southern California which resulted in a "compromise" motor and other than changing the exhaust every 2 years, the car easily passes the rolling dyno tests...
I'd be interested to hear what you end up with for static compression and how you got there...:)
Ralph
pete917 09-07-2006 07:39 AM
Sounds like a great car. Have you got some pictures you could post?
Im a bit luckier in the UK, I use Shell Optimax fuel which has more than 98RON.
It should only be a few more weeks and Ill be able to report back on all of the interesting stats.
Carrera3.5L 09-07-2006 07:32 PM
I've never been shy to post pics, although by searching you'll find the same ones over and over and over...:)
Apologies to Mr. Clarke, this thread kinda spun out of control and went from your question/problem to Pete's...:)
This 100mm Mahle piston/cylinder should be what you have as well...
http://forums.pelicanparts.com/uploa...1157682387.jpg
Getting closer...
http://forums.pelicanparts.com/uploa...1157682456.jpg
Ready to install...
http://forums.pelicanparts.com/uploa...1157682503.jpg
In the car with approx. 10K on it...
http://forums.pelicanparts.com/uploa...1157682609.jpg
Maybe we should start a new thread if Mr. Clarke deems appropriate?
Ralph
pete917 09-08-2006 02:42 AM
thanks Ralf. Very impressive.
Yes the MAhle's look familiar. I was wondering if the deck height with this replacement are problematic with regard to deck height. Mine is all gone, yours was initially 0.5mm... hhhmmmmm.
I'll try and dig out some photo's of mine as it comes together.
pete917 09-19-2006 10:26 AM
Ralph,
With regard to compression I wonder if your original result was because of the US versus European specs. I understand that the CR for a 3.2c is 9.5:1, wheres the CR for a euro spec 3.2c is 10.3:1. I wonder where the difference is in the two cars when original. If its in the heads then that might go some way to explain the differences.
Im about to measure my CR, so will report back with the numbers soon. Meantime, do you have the calculated volume of the dome of your pistons?
Cheers
Pete
Carrera3.5L 09-19-2006 08:08 PM
Cheers
Pete
Hi Pete,
Here are all my pertinent calculations:
Deck Height - .75mm
Head CC - 88.8
Dome CC - 25.863
Swept CC - 584.04
Deck CC - 5.8875
Swept CC + Head CC + Deck CC - Dome CC divided by
Head CC + Deck CC - Dome CC = 9.49:1 CR
Andial (one of the Mahle distributors) claims this is a 9.5:1 set, whether using the DME or RSR style piston. The other distributor (SSF Auto Parts) advertises them at 10.3:1 but they are simply a parts reseller and pass on whatever info Mahle Motorsport spoon feeds them.
Good Luck! I'm interested on how it turns out for you...SmileWavy
Ralph
