Guys,
How many tools you own, how many engines built, what your budget is, isn’t the issue. These engines can be built by an absolute novice, with technical help from this Forum and the technical literature available. That said, it still takes great care. Sure the more specialized tools help the process. I’m off in the extreme because I bought all mine for my shop mechanics. I still have around $90K, maybe more. The recommendation for disassembling a “core” 911 engine is right on. Not only should you dissemble but you should reassemble practicing the skills necessary to do it right and for real. The advice here for outside work is correct. Many shops sub-contract much of the engine building. Even I (Rennenhaus) didn’t grind the crankshafts, X-ray the rods or a few other processes. We did all the head work, that was there the power and longevity was, among other. Most today have the heads done professionally; have the crank & rods done professionally, and a few other operations. The key is to be able to measure the sub-contract work better than they can do it. This way your supplier gives you the best work possible because they know you check. You can even sub-contract out the inspection. How do you think NASA gets a Shuttle to fly? Best, Grady |
amen
Probably $3500 in tools and I'm sure I started with a lot less and I can do most of it in my 2 car garage. The difference between the average DYI guy here is that we have to take our time and go slow and methodical. The big dogs kinda need big $$'s in the tool bin but their niche is that they get you your engine/trans/car ect. in a couple weeks. We get home from work and give it 4 hours here and there....Plus the big dogs are usually nice enough lend us that odd p213a tool here and there too. Just be speedy when your done with it!! Get that core, take pics while your stripping it. Do it alone and ask your questions here. You are assured speedy, knowledgeable replies. post pics on this site too. We like them and it helps.
Nabil |
I do have to agree with Henry on one thing. For certain jobs you need the correct tool, PERIOD. These are the tools best borrowed or rented as they usually cost to much for a single engine.
The subject of HEADS is one that is given much to much preferance to the PROS. Heads are one of the easiest parts to recondition and the investment in tools is modest. Valve guides. A $20 Punch is all that is needed to remove and install new guides. Do this yourself. Reemers. again $30 will buy you a reemer that will size your guide to the proper size. Do it your self. A Neway valve seat cutter set of three, say 5 cutters for both intake and exhaust valves is about $300 new or $50 at Pomona. This will allow you to recondition the valve seats like new. Valves. Have them reground at a local machine shop or buy new ones and you are good to go. Porting, this is a major joke for a Porsche. The port matching is already done to good nuff for most people. All that is needed is a $10 carbide cutter and a $10 die grinder from harbor freight or an electric one for $30. Just grind out any flashing or rough stuff on the short side radius of the intake and exhaust and you are finished. With Porsche this will be a 10% improvement at most in power. Chevys will get you 30% or more improvement. Heads should be a DIY for most Porsche guys. The special cutters from Neway can be rented or borrowed as well as purchased. No reason not to DIY. Only the all out race heads, and I mean ALL OUT race heads need porting by the pros. If you are going to keep it below 8000 rpm DIY. Bottom end oil mods need pro work. You can mod the case for improved air flow between cylinders yourself using the diegrinder. Balancing of the crank is up to the pros. The pistons you can diy. Just weigh them on any gram scale and machine off a little on the inside underbelly untill they all weigh the same within one gram. The rods need some kind of balance to weigh just the big end and then the overall weight, Again within the diy relm. You do need a pro to oversee the whole thing, you need to pay the pro for this time. I would contract with one for a negotiated price for overall advice and I would buy all your parts thru him (that gives him his markup and helps pay for the advice). Otherwise you just give the markup to someone that gives you nothing in return. Most guys, and I suspect even Henry will give you advice if you purchase all your parts thru them. You pay a little more, but you get what you pay for. |
Grady, wise words, as usual.
Cheers |
agreed,..to the novice a valve job seems like a big deal, but is not really. I highly recommend just throw the exhaust valves and use new. Dry ice for guide install for the tightest fit (heat transfer) (heat the head too)
I had a pithy somewhat sarcastic response to the previous posts but I really lost interest in pursuing the inconsequential banter.
While it is true that "no one know it all" it is also true that "experience has value". It is also true that "everyone is entitled to their opinion and opinions very". The important thing is the basis for the opinion. Is the opinion based in actual knowledge? Is it based on theory? Or would an opinion based in actual experience mixed with expertise be more valuable than an opinion based in a hobbyist enthusiasm. When an expert offers his/her opinion and you choose to ignore it, the looser is not the person offering the advise. BTW: The right tools is never a waste of money. If you are enough of a motor head to want to build a Porsche engine, it is a reasonable assumption that this project will not be your last. Having a quality set of tools will pay for itself very qickly. If you can barrow a tool, that's cool. If you barrow it twice you're just cheap. As for the suggestion that I only offer advise in order to sell parts, that is just plain crap. |
I am happy Orville and Wilbur did not listen to the black Smith. What was that about original thought ?? 'ya wanna make a a flying machine ??,You cant do that !!,.Show me someone who says it cant be done - and I guarantee some one will step up and do it.
I know there are and is a lot of valuable opinions , thoughts, ideas here. I would not want someone to be quiet just cause they dont own a repair shop............. |
What I might say is "there is a better way to do it". That is where the experience comes in. |
Paul, If after reading all these posts you still have the desire, I want to encourage you. This has been a very satisfying hobby for me personally. I've made some of the dumbest mistakes imaginable in re-building, but with advise from some folks here, and a lot of perseverance, I've managed to finish a motor and trans. Can't even begin to relate how good it feels just to fire it up, let alone drive it. Jump-in! Have fun!
I will second Henry and Jon … and even some afterburning.
You will find lots of help here (banter aside) and I, for one will start looking for a core subject for you. I have previously posted lists of manuals and technical publications. You should buy all of these and start yourself a “Personal Car Specific Notebook.” You can include in it all the relevant posts from the Pelican archive and more. On to a different subject. The issue with Porsche cylinder head repair isn’t so much about the valve seating. Yes, that is very important but the underlying valve guide is far more critical for longevity. Replacing valve guides correctly isn’t easy and combines a high level of skill with some very special tools. You need to measure dimensions less than 0.0001”. Yes, just about anyone can step drill the old guide, hammer it out, install a new guide and ream it so the valve stem fits. There is far more to it in order to have things last or not have a problem. The surface finish, size and straightness of the valve guide bore in the head is critical to installing the guide. Removing the old guide without damaging the head is the first step. Being able to step-drill the guide so there is only a few thousands of guide is not something you can do by hand. It is done with a fixture at the correct angle and on a mill or good drill press. Once the guide is out, you need to be able to measure the bore in the head. This requires an assortment of high quality measuring tools. You are measuring very close tolerances here. You need to know if the bore is straight, round and what size. Almost every time you need to hone the bore (with a Sunnen hone and coolant flow) to get the proper condition. The reason for all this effort is if the bore-to-guide interference fit is too great the head can crack. If not enough there is poor heat transfer or the guide can actually loosen in the head. Of coarse the quality if the fit also influences how well the bore of the guide can be finished to fit the valve stem. The bore in the head must be done to fit that individual guide. Once the guide is installed the bore in the guide undergoes a similar process to fit the valve stem. Anyone can run a reamer through a guide and have the high points clear the valve stem. The “art” is to have the entire bore be the correct size. This gives longevity to both the guide-to-valve clearance and to the resulting valve job. This is also critical for proper cooling of the valve. I have seen fresh valve jobs where the guide was too large bore when new. Of course the valve wouldn’t stick in the guide because it was worn out to start. In all of this the axis of the bores can’t change or the seat will require too extensive work. Once you have a proper new valve guide, you can then use a Quickway grinder and Neway cutters to have a proper multi-angled valve job and proper sealing surface. You can’t do a good valve job with a crummy valve guide. There isn’t anything magical about all this but experience and the proper tools result in a correct and long lasting job. An issue that the shops are currently dealing with is the “too good” valve stem seals that don’t let enough oil to the valve to guide interface. There seems to be a consensus that this is a major cause of premature valve guide wear. Best, Grady Jon, how did you get an in vitro image of me? HeHe. Good one. |
Way overblown on the difficulty in doing valve guides. TOtally unrealistic to say the least. If you have seen some of my past posts you know I have access to all the best Sunnen ever made, you simply do not need it unless you have a trashed head with major problems. If you have to replace a valve seat, then you need good equipment (I also have access to the best made for this), but if all the seats are reasonable to begin with, you are good to go. The original bore must match the original seat, within reason, and within maching tol for Neway cutters. Guides are the most important and must be good. Just knock out the old ones with a punch (from the cylinder side). Press or knock in the new guides. The std size is a press fit and really dosen't need adjustment or machining. If however the new guide simply slides in easily, then you should take it to a shop. But most likely it will require a firm hammering to get it in. Then a reamer is all that is required. Reamers are ultra precision, no need to measure. The valve stem can be miked easily. If its in spec you can feel if it fits ok. It must slide easily, but not rock back and forth with a 1" protrousion, see most rebuild books for details. If you cut the seat using the new guide, you can see if its ok, and with some bluing or magic marker and a fresh valve you can check for everything you need to check, no special tools required. I personally like stones better than cutters, but the cost is high and the return negligable. I can and do use stones for valves as well, this lets me do 5 angle valve jobs quite easily. But only a racer would benefit from the 1 or 2 percent improvement of this valve job.
Henry, theres ALWAYS a better way to do it. But if it works, it works. Leave it to Henry to misinterpert a statement by me. Of course you wouldn't give advice just to sell parts. But you are in business arn't you? If someone offers to buy all their parts thru you in return for some advice, why wouldn't you do so? You might give the advice anyway, but its a much fairer trade if the guy pays you something for it. So the guy willingly gives up 10% discounts and you make your usual 3x markup. In fact you could still give him his 10%, thats all the average joe can get, and make 2x, ie you both win. Or are you so greedy that you insist on doing all the work yourself? |
Henry is always trolling.......................................... .............................
WTF.... Put down the pipe(s). Henry, my take on you...completely from this website is.. Total engine art, combo of high technical skills, combined with attention to the asthetics. Afterburn.. total DYI to the max. That is a good thing. Again, a combo of technical skill combined with a sense of asthetics. (based on this site and local reports) Different though...very different.. that is what makes this a good site. lot's of excellent advice. Get past the occasional tangent into ego land (mine too!) and it's all good. (I like the tangents too) Paul, you're getting advice from the best, but you have to filter out the horsecrap. The total dollar amount spent on tools is not the issue and only somewhat relavent. It's dictated by what you think you can do yourself while educating yourself and what you need to shop out. Buy Waynes and Bruce Andersons book. Hook up with the local yocals and join in on an engine drop and rebuild. You'll quickly understand what tools and knowledge you have/need. Everybody local and on this board is typically willing to help. I was a newbie 10 years ago and I have two engine rebuilds and many other DYI fixes under my belt. Not trying to be a peacekeeper. I like the tension, it's more fun. but ... and it's a big butt.......
This is a do it your self forum, and we all aim to help ea other do it to it !!
......If you have never taken a basic eng. apart at some age in life ( hopefully b4 14 yrs old ) then maybe a P car will be a big bite too chew on. There are basic nut and bolt skills that one has to learn in practice that could never be taught. Other then that its just an other IC that goes suck ,boom ,blow, with a few features that dont come on a domestic v8 ,,like fully adjustable valve timing . The "other" tools that you will need aside from your basic set will almost acquire themselves as you get to that procedure. ( you will have no choice therefor they are ) Have a happy time as I know you will. sincerely from all of us. PS.- just ask when you get there. |
What is WTF?
profanity, what to f----
What is DYI?
Do It Yourself.
From another old LC owner (also '84). Best, Grady |
Dyslectic ? Me too
Did you hear about the dyslectic, atheist with insomnia who stayed up all night ranting "There is no dog !!" :) Please, those of you with dyslexia don't take offense. Those atheists among us (you can keep on ranting). |
Core engine is a great idea. I bought a 69 2.0 engine for $200, bought Wayne's book and had a great time. Only "special tool" I need for teardown was the cam tool, and I learned tons over 2-3 weeks. Plus, I made a few bucks selling the bits & pieces.
Dang. Where do you guys get engines for 200? I'd love to find one for that cheap.
Anyhoo, once I was off New Project Probation, I got Wayne's book, a couple special tools, and disassembled the engine. I sold off the parts, but was careful to state that I was a newbie and that if there were any issues with the items they would be refunded in full. All in all, a great introduction and made a few bucks too. The crank is scrap, but I think it would make a REALLY nice lamp. Mrs Notfarnow thinks otherwise. |
"The crank is scrap, but I think it would make a REALLY nice lamp"
That sounds like a garage furniture idea. Of course, then you'd have to build a table out of an old deck-lid or something to sit it on. :) |
My suggestion for a core engine was born out of experience.
All my trainees start that way. I once hired a mechanic with a great resume, including "Crew Chief of the Year, Indy 500." After a short time I discovered that his knowledge of Porsche engines was zero. I put him on a core engine and within a couple of days his knowledge of Porsche engines quadrupled. Good idea, I believe it's the best way to start. Where it is true that almost anyone can build a Porsche engine, it is also true that like anything else there can be art in it. My intent is to bring out the art in my mechanics and not everyone is an artist. It is also true that getting into this type of project for the first time can be overwhelming. If you take the engine in your car apart you must get it back together even if rebuilding it is not to your liking. If you play with a core first then rebuilding it becomes an option that you can complete or not. The other up side to buying a core is that the core can be an upgrade. I.E.. 3.0 for a 2.7 car. You can rebuild the core and still drive your car during the rebuild. |
| All times are GMT -8. The time now is 09:35 AM. |
