964 to RSR-alike
Hello Chums.
I'd apprecaite comments and advice, about what parts are out there to help me make a 964 motor look and run like an RSR. I'm thinking twin-plug from Henry and Burn-Bros, cams from John Dougherty, MFI from Henry..what core pump? slide or high-butterfly from ? This is the first problem..the three-bolt inlet ports.. I can make adaptors, but will not be surprised if someone has already made the right parts.. Fan ..looks wrong..any ideas? High flow will be needed.. Headers etc easy.. Flywheel from germany.. (Does anyone know the maker of these special flywheels to save a long search please?) What rev limit must I work to? Would better and longer rods with special pistons improve the rev-tolerance? Kind regards David |
David: I've contemplated going to MFI on my 3.8 engine rebuild. I have the adapters to make it work...I got them from Bruce Anderson. If you want dimensional diagrams to make your own, let me know. I can have a friend create a schematic for you. the big issue with an MFI conversion is getting someone to cut the space cams for you. I've talked to Gus at Pacific Fuel injection about it. He said its doable but may bery well end up being a trail and error process (read time and $$$). You'll need MFI throttle bodies bored BIG....at least 42mm. You are probably better off going to carbs if you want the early look.
Thanks, Felmir.
Yes I'd like the diagrams please. I may have a solution to the space cam issue..not sorted yet..will advise if it progresses. david.leopold at virgin.net is my email..thanks David |
David, the 001 or 005 pump is the best solution for big bore conversions, as you prbably already know. Does this mean you are now looking for a third pump? :)
Hello, Kenik.
Ha! Guess so! I'm still ignrant about this tho' what is different in those early pumps to make them more adaptable, do you know? BTW, I will be happy to do the swop at your convenience.. Thanks David |
Just get a hold of Henry Schmidt and let him know what your looking to do.
You will probably be more than pleased with the numbers he gives you, then give him the O.K. and within 60 days you will be STOKED...It really is that easy:D |
Henry just completed this motor for a friend of mine. This thing runs, like
no NA 3.2 I have ever experienced, hard to describe, and the sounds----WOW. Supertec 3.2SS, Twin Plug MFI with 52mm throttle bodies!!! http://forums.pelicanparts.com/uploa...1154894490.jpg Henry has it down with MFI and KNOWS what works. Eliminate the guesswork, call YODA. |
adaptors
David I have some adaptors that go from 3 bolt 3.6 heads to 2 bolt pattern and they have the threaded hole for the MFI injector.
350.00 shipped Mike Bruns |
| All times are GMT -8. The time now is 03:58 AM. |
