anyone have a pic of Henry's 2.2 sealing rings
looking for a visual aid of Henry's 2.2 sealing rings and how they would close up the combustion chamber to use them on a 2.0 bore
(I assume a different sized ring is used on an 81mm bore, but looks the same?)
also would love testimonials from those that have tried it.
I'm about 99% ready to make the plunge and go with the 2.2 heads, but just want a little reassurance first before I spend the money.
thanks in advance
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-01-2006, 02:52 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I do !
Here's another option, 81 mm Nikasil 906 cylinders for 2.0 or 2.2 heads.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-01-2006, 06:39 PM
Henry,
thanks so much for your time and the education today.
I've got a lot of thinking and decision making to do now.
thanks
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-01-2006, 08:03 PM
