Head stud tightening methods
I have searched this but couldn't find an answer. This is for a 3.2.
Factory manual says 11 ft-lb then 90 degrees, with no mention of reotorquing
Wayne's book and several posts say two stages, final tightening to 23.5, with re-torquing after a bit of running.
I followed the factory method - the nuts are considerably tighter than 23.5.
Also, there is no way to re-torque later with the tighten then 90 degree method. To the best of my knowledge, when bolts are tightened by a stretch method (which essentially the factory method accomplishes) there is no need for later re-torquing. Properly installed rod bolts would be an example.
So, what is the right thing to do?
Bob D.
'84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 21/27 TB, 22/21 SB, bunch of other little stuff
'74 Fiat X1/9
2021 X5
Old 07-30-2006, 06:05 PM
A few people recommend re-torquing headstuds. The rest of us and the factory recommend not.
-Andy
Old 07-31-2006, 08:41 PM
Super Moderator
cstreit's Avatar
I've always checked mine on new engines after a few hundred miles or so... Never had one that needed to be re-torqued...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-01-2006, 11:52 AM
Do you use a torque spec or the turnof-the-nut method for tightening at assembly? If the latter, what do you use as a spec to check later?
Bob D.
'74 Fiat X1/9
2021 X5
Old 08-01-2006, 04:50 PM
