Stranger on the Internet
patkeefe's Avatar
Rocker Shaft Seals
So, after looking at my rocker shafts today, reading a bit about the RSR o-rings and this thread, I got to wondering if it is as simple as finding some o-rings to fit the grooves in the seals. Those grooves are pretty deep. But, I have the engine apart, and now would be the time to do it.
Anyone ever simply o-ring the grooves in the shafts? Seems as if it would be good insurance. Or, is this another wet dream from my overactive imagination?
Pat
Patrick E. Keefe
78 SC
Old 07-29-2006, 07:31 PM
CBRacerX's Avatar
Pelican sells the seals andd they are recommeded.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 07-29-2006, 08:30 PM
Irrationally exuberant
ChrisBennet's Avatar
The seals are not normal O-rings. They are shaped like rubber washers. I have searched but have not been able to find an alternate source for these relatively expensive seals.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-30-2006, 07:39 PM
patkeefe's Avatar
Thanks Chris and Chris:
I have been doing some more research on these seals; the camp seems split 50 - 50 on the use. My daughter and I cleaned out all of the shafts and retainer cones and through bolts. checked the OD on them, checked the ID on the rebuilt rockers from Camgrinder, and the ID on the bores in the cam towers. Everything is per spec, and when I torque up a through bolt on the shaft, it does indeed swell the shaft end about 0.0015", which makes a good positive seal. Whether this seal will in fact seal effectively for any period of time is the $64k question. I suppose if I can get these seals in a few days, I'll get them in, as I'm starting to get pressed for time on getting the SC back togther. Else, I'll take a flyer on the no seal installation; worst case, the engine will be back out over the winter for 915 work and intercooler fitment.
BTW, John does a nice job on cams and rockers.
Thanks!
Pat
Patrick E. Keefe
78 SC
Old 07-30-2006, 08:11 PM
CBRacerX's Avatar
Pat -
I had John do my cams and rockers - I am pleased as well. The seals were not that much, and they seem readily available from Pelican, EBS, etc. Leaks are a bummer and it seems the 911 will zap you every chance it gets to leak oil - might as well stack the deck in your favor!
Chris
Chris
Old 07-30-2006, 09:18 PM
Jk369's Avatar
Try ********.com
'80 SC 911
'67 Chevy SS Nova - Supercharged
'99 GSXR track only, '99 Superhawk
'05 Toy PU - daily driver
Old 07-31-2006, 09:23 AM
Air Medal or two
afterburn 549's Avatar
might a well as they are a bummer to do it in place....dont ask me how I know !!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 07-31-2006, 07:26 PM
Jeff Alton's Avatar
I look at it like this..... The seals will not cause a leak, and may very well prevent one, so to me, they make sense. If any one if thinking of getting some made that is a little cheaper I will take 250 of them......
Cheers
www.turn3autosport.com
Old 07-31-2006, 09:51 PM
