-   -   Question on Wayne's book (http://forums.pelicanparts.com/911-engine-rebuilding-forum/297380-question-waynes-book.html)
Clay Perrine 08-06-2006 08:01 PM
I have a 76 930 engine that I am considering rebuilding as an NA motor. CAn I use the 98 MM pistions and cylinders to make a short stroke 3.2 with the turbo crank and rods? Will the heads and valve sizes work OK?
Also, can I run MFI on this?
Thanks in advance.
Henry Schmidt 08-09-2006 12:02 PM
That case is too valuable to use as a short stroke 3.2.
Sell that case and crank, get a 3.0 -3.2 case and run a 3.0 SC crank. It is a better crank and you will find that the SC or 3.2 Carrera case will fit all your other parts.
3.0 turbo heads with porting make great NA heads.
BTW:
I am always in the market for these cases.
