Question on Wayne's book
I have a 76 930 engine that I am considering rebuilding as an NA motor. CAn I use the 98 MM pistions and cylinders to make a short stroke 3.2 with the turbo crank and rods? Will the heads and valve sizes work OK?
Also, can I run MFI on this?
Thanks in advance.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 08-06-2006, 08:01 PM
Try not, Do or Do not
Henry Schmidt's Avatar
That case is too valuable to use as a short stroke 3.2.
Sell that case and crank, get a 3.0 -3.2 case and run a 3.0 SC crank. It is a better crank and you will find that the SC or 3.2 Carrera case will fit all your other parts.
3.0 turbo heads with porting make great NA heads.
BTW:
I am always in the market for these cases.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-09-2006, 12:02 PM
