Va914's Avatar
Engine temps
I was checking some engine temps with an IR gun and found some weird temps
The 1-2-3 side runs 500F about 2" down from the heads
The other side is getting weird..
6 = 350F
4-5 = 175F
What would cause the difference and the really low temps?
I pulled the plugs off 4 and 5 and it does change the idel but very very little and close to not at all??
Cheers
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 08-23-2006, 03:51 PM
DW SD's Avatar
As you've deduced, I would suspect those two cylinders aren't firing.
You need, air, fuel, compression and spark to burn.
Can you verify fuel and spark?
How about doing a compression test on those cylinders?
Doug
1971 RSR - interpretation
Old 08-23-2006, 04:10 PM
Kerry,
Tell us a little about your engine.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 08-23-2006, 04:38 PM
Va914's Avatar
Opps
I have a 2.2T with webers and Crane ignition. The car seems to run fine
I pulled the #4 plug and it was white'ish in color. It is not fouled and is dry.
Not sure how I can check the carbs for flow? I have 3psi at the gauge and the squirt thingy is squirting fuel when the linkage is actuated??
914-6 in the Werks
Old 08-23-2006, 05:18 PM
Va914's Avatar
Did a search and read about the cam being installed 180 deg off? Any thoughts on this?
914-6 in the Werks
Old 08-23-2006, 06:31 PM
Va914's Avatar
I was reading on the bird board that it is very easy to install the cam 180deg out and still have the engine run okay??? The engine runs fine (at least as best I can tell). I don't have another 911 2.2 to compare to but it seems okay to me.
I don't think I did this but will check it this weekend. It's just funny how the two sides are so different in temps?
I will also have the wife rev the engine to about 2000rpm while I pull some plug wires. At idle there is very little if any change when I pull #4 and #5 wires off.
I guess I could put the IR temp gun away and then things would be back to normal LOL
Cheers and thanks
914-6 in the Werks
Old 08-24-2006, 06:47 AM
DW SD's Avatar
Did you test compression on 4,5,6 and compare to 1,2,3? That would be a great place to start.
The squirty thing is likely your accelerator pump adding fuel.
Doug
Old 08-24-2006, 10:01 AM
you can check if one cam is 180 out...watch the cam lobes and as e.g. #4 comes to tdc after the intake valve closes...go look to see that the roter is pointing to the #4 sp wire position
Sold: 1989 3.2 coupe, 112k miles
Old 08-26-2006, 04:56 PM
