Bead blasted Mahle's 3.2L cylinders. What do you think?.
Used 3.2 Carrera P&C's
Hey Guys, I am thinking about buying the set of 3.2L mahle cylinders in the above link and wondering if bead blasting the outside of Mahle's cylinders is a bad thing?. Wayne's book did not recommend the cylinders to be blasted, or did he mean the interior of the cylinders?. The seller said that the inside of the cylinders are fine. Can anything bad comes from bead blasted cylinders?. Thanks for all your help. Andy |
As long as they didn't do the inside they should be fine, we used to bead blast cylinders from air cooled airplane engines to clean them. Bead blasting is a lot less erosive (sic?) than sand blasting.
Robert Currently Porsche less (but the wife has 2) |
agreed.
What id bead blasting ( sorry i am Danish :-) is it with glass, plastic or som very fine ceramic powder ??
Roslin
Porsche 911 SC 3.0 |
I bead blasted mine but I first taped up the openings very well, they came out really nice. I also modified my hone to use fine scotch brite pads to clean the inside of the barrels. I did it with a bit of oil but most recommend to use hot water and soap instead.
Good Luck, Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
Thanks guys. The P&Cs are on their way. Andy
Roslin:
The reference here is to glass bead blasting,...... We use soda blasting equipment (same as the aircraft industry) since it leaves a natural finish and cannot peen or damage metal in any way. This ensures that the Nikasil bore won't get accidently damaged.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
this may not be an issue with just doing the outside of the cylinders... but you can read in a number of places to be sure, 110% sure, that for any reason glass beads not get inside the engine... to me this means not even letting glass beaded parts or material on the property while an engine rebuild is in progress... if it was me I would use something else e.g. walnut shells or just chemicals... that's my 2 cents.
Sold: 1989 3.2 coupe, 112k miles |
Thanks to all of you for the replay !
Roslin
Roslin,
You are getting good advice here. I agree that most important is to keep your rebuild absolutely clean. This is particularly true of cleaning media. Processes that don’t have the possibility of contamination are clearly best. Some techniques (sand or glass) have the advantage of roughening the surfaces for better heat transfer. At the same time, extreme care must be taken to prevent any media inside the engine. There are different processes for different parts of the engine. There are even different processes for different surfaces of the same part. Masking and other protective measures are extremely important. The goal is to have the surface appropriate for the use. That can be cooling, friction, beauty and more. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
