Oil Pump Advice - '83 930 Rebuild or Replace
I'm doing a complete rebuild of an 83 930 and I am considering my options with respect to the original oil pump. As a threshold matter, the case, crank, rods, etc. all measure to spec and the internal components (pistons, cylinders, cams, rockers, etc.) are all pristine which indicates the oil pump was doing its job perfectly. (the rebuild is the result of broken head studs.)
Does anyone have guidance on disassembling the oil pump to check for wear and tolerance on the internal components? Is that action necessary? Can the pump be tested for pressure and flow without disassembly? Is it a far better thing to just upgrade to a GT3 oil pump?
Any input or experience would be appreciated.
Thanks,
Duane Duclaux
Richmond, VA
'79 911SC Targa -- "BLUVUDU"
'83 930 Coupe -- "TURBAUX"
Old 12-06-2006, 07:37 AM
Air Medal or two
afterburn 549's Avatar
I would suggest TBO...sort of, how many miles on it ?? 100,000 ok (maybe ) 200000 i would replace for sleep ezz .I dont know that they are failure prone...I do know it is the hart of the eng. We both know it is in a bummer of a place if you have to pull it later......
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 12-06-2006, 01:49 PM
Cymru am Byth
carmad's Avatar
I had mine serviced by EBS Racing in Nevada. Had 67,000 miles on it, they said everything was in spec, and ported it for better flow.
No problems after 6000 miles and several track days.
It cost about $150, IIRC.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 12-06-2006, 02:27 PM
I went thru this a couple of years ago when my engine was rebuilt. I went with a new pump for piece of mind.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 12-06-2006, 06:14 PM
Walt Fricke's Avatar
Porsche Crest
Hell - if it were mine I'd inspect it. Look very closely through the openings while rotating it. If I saw nothing nasty looking in the way of scrapes or dings or battle scars (especially on the edges of the teeth, where something could get caught between a tooth and the case), and the engine had fine oil pressure, I'd put it back in.
There really isn't anything to replace/rebuild, I think, on these. No bearings or bushings. This is the mighty "Turbo" pump, right? Large pressure section, large scavange section, short stubby splined tube connecting it to the IS shaft?
You can pour oil or some suitable fluid (kerosene?) in it and spin it by hand. Not much to learn other than yes, it will move the oil through. To test it you'd have to fabricate a lot of stuff, including something to spin it. Haven't heard of anyone doing that, but who knows.
But I'm cheap and a gambler - you said the engine's innards were just fine (so you are in there just in case to replace bearings, right?). This is a very good pump as a general matter. Why worry about this. Have buddies been filling your ears with tales of premature wear on 911 oil pumps? This is not an obvious thing to replace during a rebuild. Those bearings that looked OK, sure, replace them anyway. But a pump?
Walt
Old 12-07-2006, 12:37 AM
resident samsquamch
sand_man's Avatar
Neil Harvey of Performance Developments rebuilt the oil pump in my '87. According to him it was well within spec. FWIW, I had no real catastrohic failures in my engine, when I decided to rebuild it at 42,000. It was mostly just to upgrade some things, and seal all the oil leaks.
-jeff
Old 12-07-2006, 06:23 AM
Loose nut bhind the wheel
You need a new one. Send me the old one I will pay for shipping. LOL
Inspect it, No obvious play in the shaft or damage to the internal gears, Run it and forgetaboutit!!
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 12-07-2006, 11:30 AM
WydRyd's Avatar
If you've done a complete teardown, it might be worth fitting bigger piston splash valves, for better piston cooling.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-07-2006, 08:10 PM
Thanks to everyone for their thoughts on this. I will post pictures of the rebuild for all to see and comment about all the things I am doing wrong.
Old 12-08-2006, 12:35 PM
