-   -   Your input on 3.0L engine with 3.2L Ps/Cs please (http://forums.pelicanparts.com/911-engine-rebuilding-forum/305383-your-input-3-0l-engine-3-2l-ps-cs-please.html)
flatsixcrazy 09-20-2006 11:04 AM
Hi everyone,
I am thinking about putting together a 3.0L engine with 3.2L Mahle Ps/Cs (for street and occasional DEs in a 1972 chassis) and hoping that you can give me some input on what to pay special attention?. Here is what I have so far:
- 3.0L case with std. 70.4mm crank,
- set of 78SC heads or a set of SC ported, twin-plugged heads I
am looking to buy from Scott Kinder (YTNUKLR),
- set of Sc grind (will be 964 grind) cams
- CIS set up
- Set of 3.2L Mahle Ps/Cs for CIS
-SC single plug ingnition
What else am I missing?. I will have the SC rods machined to use with the 3.2L Ps/Cs and get a set of 23mm wristpins.
Future direction for the same engine,
-Higher compression JE pistons
-More aggressive cams
-40mm IDA Webers
-964 distributor
Thanks you all in advance for your inputs. Andy
Jeff Alton 09-20-2006 01:22 PM
I am confused about your description of the P/C set. Are they 98mm for use with a 22mm pin (SC rod) or are they 95mm pistons from a 3.2 that have 23mm pins?
If they are 95mm from a 3.2, save your money. They have the wrong pin diameter and they are designed for a shorter rod and you will still have 3.0 displacement as the 3.0 uses a 95mm bore as well.
Could you clarify?
davidppp 09-20-2006 04:16 PM
Yes, still 3.0 L..
But the 3.2 piston is a much better piece allround than the 3.0..and offset drilling the pin bore in the rods makes up for the loss of compression height.
Kind regards
david
flatsixcrazy 09-20-2006 06:32 PM
Could you clarify?
Hi Jeff, it's what Henry said in this thread that got me going http://forums.pelicanparts.com/showthread.php?s=&threadid=245455&highlight=camsha ft
Hi David,
Have you completed your 3.0L engine using the 3.2L Ps/Cs yet?, or did you go with something else?.
Andy
YTNUKLR 09-20-2006 07:04 PM
Andy, as shown by Herr Schmidt II (Henry), the 3.2 P/C can work well on the 3.0L base. I think the heads that I have for you will work very well on this config., and I'm not just saying that so you buy them ;). Obviously you can stick a dummy plug in there and run it as a single-plug motor, and upgrade when you want to, down the road.
Another great combo (that you may decide if/when you install JE pistons) is changing the cylinders to 98mm, either with Nickies, QSC or bore your 95mm Mahles and replate, etc. That will give you 3.2L but with a different borexstroke (98 x 70.4)from Porsche's original 3.2 (74.4 x 95mm).
I have a 3.2L (stock) engine on my stand right now. Originally, I ordered 964 cams for this motor from Camgrinder (on the forum). Now, it looks like we're going with something different--perhaps a modified DC20 or maybe even something a lot hotter if this guy decides he wants carbs and JE pistons instead. So, I have a set of brand-new 964 cams for sale, if you're interested. I'm sending you another PM.
Best regards,
Scott
flatsixcrazy 09-21-2006 04:09 PM
Thanks Scott. I already have a set of 3-bearings SC cams and I won't know what to do with it if I buy your cams. So, I'll send it out to have it regrind. What would be a good cam for this engine if I were to run the 40mm Weber on it?, with CIS pistons?. BTW, I just send the payment for the heads via paypal. Thanks. Andy
YTNUKLR 09-22-2006 07:54 AM
Thanks Andy. A good cam for CIS piston/Weber 40s is the 964 or even the 3.8 Supercup from John D. @ drcamshafts.com.
Cheers
