-   -   Which way does rotor's turn on 964 twin plug? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/309554-way-does-rotors-turn-964-twin-plug.html)
JoeMag 10-13-2006 06:42 PM
Thinking of maybe using that setup on my 930 but I think it turns the other way... Can the gear on distr be changed? ...I know can do on crank, but don't feel like breaking into case.
Toyed with 12 single, but calling andial, the cap and rotors are no longer made, so they're have them made -- $600 cap, $500 rotor!!
AFJuvat 10-13-2006 08:12 PM
Clockwise
The gears are removable, but I don't know if anyone makes the gear that you would need.
AFJ
89turbocabmike 10-13-2006 10:22 PM
Joe, you would have to change dist. and crank gears. Check Henry - Supertec performance, his 12 plug distributor uses the jag cap and burns-bros rotor for around $500 for both. I think his distributor with cap and rotor was $1500 last I checked, and won't require a crank gear change.
JasonAndreas 10-13-2006 10:45 PM
Re: Which way does rotor's turn on 964 twin plug?
The gear for the distributor might be part #930-602-422-03 and you'll also need a new pin #930-602-922-00.
Henry Schmidt 10-13-2006 11:16 PM
In order to use the 3.6 twin rotor twin cap distributor on a 930 you must change the drive gear on the crank. If you just change the gear on the distributor the mechanical advance becomes a retard.
Supertec makes the only after market twin plug distributor that adds a support bearing directly under the rotor to insure proper clearances and long rotor and cap life.
When you compare the cost of two caps and two rotor plus belt maintenance you'll find that our cap (Marelli) and rotor (BurnBros) is comparably priced.
We can build these distributors to suit all applications. That means in the case of a turbo engine we can add a vacuum advance and boost retard.
http://forums.pelicanparts.com/uploa...1160806291.jpg http://forums.pelicanparts.com/uploa...1160806335.jpg
