-   -   Broken Plug, Engine Harness, Distributor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/311341-broken-plug-engine-harness-distributor.html)
SP2 10-24-2006 07:14 AM
1981 SC. I dropped my engine and took off the wiring and shroud yesterday. One plug is sort of broken. It goes into the distributor and then is screwed down. The male adapter is surrounded by plastic. Now the plastic is fractured all over the place. The plastic is very thin. Any suggestions? The entire wiring harness feels a little stiff, but all but this connector escaped damage. Any suggestions?
Also, if you have time please see my post on the 911 forum about Longblock Mount and Engine Mess. I posted some questions that really has me stumped. Thanks in advance!
http://forums.pelicanparts.com/uploa...1161699202.jpg http://forums.pelicanparts.com/uploa...1161699219.jpg
MBEngineering 10-24-2006 07:47 AM
HI if you cannot get hold of any drop me a PM as I will prob'ly have a S/H one.
regards mike
Sorry go't the wrong part No' , will post the correct No' when I find it on the mico fich.
john walker's workshop 10-24-2006 08:16 AM
i recently priced one at the local dealer. about $90. then you have to cut it and add a couple of plugs to attach it to the engine harness. make sure the wires are not swapped.
SP2 10-24-2006 08:57 AM
Thanks gents! Mike, a S/H one from you sounds better than 90$ from the dealer, even if I have to mail it here from the UK. I will gladly pay you what you need. I will PM you my info. Thank you.
SP2 10-24-2006 09:01 AM
Mike, your PM box is full.
MBEngineering 10-24-2006 11:00 AM
HI I will get the shovel in there and give it a bit of a clean out. been in and only one left in there now so should be room for a PM , hands sore and shovel wornout!!
regards mike
SP2 10-26-2006 01:11 AM
Hi Mike,
Any luck?
MBEngineering 10-26-2006 01:23 AM
HI I will send one over in the post to day ,
regards mike
SP2 10-26-2006 03:16 PM
Hi Mike,
That's great. Please PM me how you would like me to pay you.
I really appreciate this!
Henry Schmidt 10-26-2006 08:08 PM
Instead of cutting the old harness and adding a plug we just replace the entire wire. With a 928 distributor lead you can replace the wire from the dist all the way to the CD.
New fresh wire and easy to do.
I'll try to post the part # for those who want a truly nice repair.
1982911SCTarga 11-03-2006 07:57 AM
Any chance we could get that part number, Henry? Thanks!
Brian
Henry Schmidt 11-03-2006 08:47 AM
Distributor ignition cable.
928 602 907 00
