North Coast Cab's Avatar
Cam Options for 3.2 w/Stock P's & C's
What are my options?
P's & C's will remain stock. Currently running with stock EFI, headers and chip. Looking at moving to Carbs along with the cam, but I know I'm limited due to piston clearances.
TIA, John
1985.5 944 GTS
Old 10-31-2006, 06:18 AM
John:
Personally, I'd stick with 964 cams.
Those work very well in your application.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-31-2006, 10:21 AM
Jeff Alton's Avatar
I have built a couple of similar 3.2 engines with the 964 cams and they are great. One was in my own car for a while. Nice addition to what you have right now. Some have used slightly larger WEB 20/21 and I am sure John (camgrinder) has a cam similar to that as well.
Cheers
www.turn3autosport.com
Old 10-31-2006, 11:29 AM
MBruns for President
JeremyD's Avatar
You can use 993 cams - although you probably won't pass smog
Old 10-31-2006, 11:55 AM
SO what would be the advantages of either the 964 or 993 cam? Assuming addition of 46mm carbs, stock redline.
John
1985.5 944 GTS
Old 10-31-2006, 05:51 PM
WydRyd's Avatar
I'm also told GT2-EVO cams works well even with naturally aspirated engines, but your idle may be a bit lumpy, which is annoying for some. I don't mind them. Sounds cool
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-31-2006, 07:36 PM
Jeff Alton's Avatar
The individual throttles that carbs offer allow you to run a cam with more overlap than a common plenum set up does. Your limiting factor will be valve clearance since you are using the stock pistons. Give camgrinder a call and see what he recommends. He has done a few sets for me and knows what he is talking about. He can fit you out with a cam that will fit your needs.
Cheers
Old 10-31-2006, 07:48 PM
RSupdate's Avatar
I am running a 3.2L with Webcam's 20/21 grind and have absolutely no complaints. zero... great cam, nice flat powerband.
The 20/21 grind is about the max you can run with the DME and still have a turn-key, no issues motor IMHO..... The 964 grind is a great cam choice as well...a bit milder than the 20/21 and probably a tad less power as well.
When it was time for me to make the decision, I was looking at either the 964 or the 20/21 and finally decided that if I was going to do it why take a half step? Both cams have a solid reputation for being totally streetable and smogable.
With all the work and expense involved I did not want to see myself wishing I had gone with the more aggresive 20/21 grind
In all fairness I was also playing with the idea of using one of John(camgrinder) "3.8 supercup" grinds which would also work with the stock DME, But as it has even slightly more lift than the 20/21 and I just plain chickened out...he also recommends at least 10.0:1 c/r to keep the power band starting reasonanbly mid-range and a somewhat smooth idle.
Anyway....just my .02.... and I'm always open to correction
Johnny Riz
1973 911 Custom Euro 3.2L "Sports Purpose"
'10 Subaru WRX-STi Hatch - modded.
RGruppe#152
Early 911S Reg.#335
Old 11-01-2006, 09:54 AM
camgrinder's Avatar
Re: Cam Options for 3.2 w/Stock P's & C's
Why do you want to go with carbs?
If you change pistons, put in a typical carb camshaft like the DC40.
The 964 is a simple regrind on your 3.2 cams. They should work with your current chip. The DC20 profile is the next step up from the 964. Either one will work with a set of 46 pmo carbs.
The 3.8 Super-cup cams do work well with 10-1 cr. They do work with 9.5-1 cr, but give up some mid range power to the 964 style camshafts.
John Dougherty
Dougherty Racing Cams
Old 11-01-2006, 10:23 AM
Carb's for their tunability per BA.
Chip woudl be custom.
1985.5 944 GTS
Old 11-01-2006, 12:11 PM
BReyes's Avatar
Motronic rocks. You have to have a chip. The 964 cam will do ya. You want more power, what is it that WydRyd is selling?
Alternatively have you thought about pmo's when choosing your carbs? They are like carbs with todays technology. I too am doing a carbed motor. I want to hear that carb sound.
Regards,
Bernard
Old 11-01-2006, 12:39 PM
RSupdate's Avatar
Re: Re: Cam Options for 3.2 w/Stock P's & C's
Great reply JD....as always....
anyway...I also ask...with the turn key driveability of DME why carbs? If you are intent on carbs...then the scenario of what cam to run is completely different than a DME compatible cam profile.
Like JD sez...a DC40 cam is your ticket if you want to run carbs..if you want stay simple and stick with the DME (like me ) I'd go with the Webcam 20/21 ...consider it a 964 cam on mild steriods.
Believe me...with stock 3.2 DME p/c you won't look back or regret going with the 20/21 over the 964 grind.
As food for thought... my 3.2L with webcam 20/21's on a Dynojet 248c at sea level with a 68 deg. f. air temp...Mahle Euro p/c, single plug using 95 octane gas, custom Steve Wong chip, full menu ported/polished heads from Ollie's....at 6400 rpm I came up with 247.6 rwhp and 217 ft/lbs torque as my best...the other two runs were nearly identical, but that was my best.
And that was with the DME flapper box and a K&N cone airfilter.
Like I said...just food for thought....
Johnny Riz
RGruppe#152
Early 911S Reg.#335
Old 11-01-2006, 07:27 PM
I still have a set of new billet 20-21s for sale if you are interested.
regards, Phil
Old 11-01-2006, 07:52 PM
Jeff Alton's Avatar
If you are going to carbs, consider an ITB set up. If you shop well it is only a few more dollars..... I did not shop well The more "middle or the road" stuff can be had for pretty darn close to the cost of a new set of PMO 46's.
Cheers
Old 11-01-2006, 09:18 PM
Thanks for all the great info.
I have a stock 3.2 w/headers, race muffler and chip, but am looking at a rebuild down the road. I'd prefer to keep the stock P's & C's and a single plug in order to keep the cost down. The two classes in Nasa GTS where it would run would allow me about 210RWHP or 275 RWHP based on the current weight of the car. I'm close to the 210 now, so when I rebuild it I'd like to be closer to the 275. I may be dreaming, but looking at options. I'd like to settle on a plan so I can start to accumulate the needed componets and lessen the financial blow.
John
1985.5 944 GTS
Old 11-02-2006, 07:56 AM
