I'm here to cause trouble
jimbauman's Avatar
Sharp edges on JE pistons
The area of these JE pistons that the arrows point to is a very very sharp edge - a couple of mm above the top land at the edge of the indent. Should this be so sharp? The thin metal might create hot spots or even melt?
Should this be left alone or machined to a smoother edge?
JB
Old 01-18-2009, 08:39 PM
3 restos WIP = psycho
kenikh's Avatar
It is standard practice to smooth these over. A light grit sandpaper works well.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-18-2009, 08:50 PM
304065's Avatar
Jim,
I did exactly that, here are the pictures in my "Jugs and Slugs" thread.
Jugs and Slugs: Confessions of a JE Piston owner
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-19-2009, 07:32 AM
I would rather be driving
jpnovak's Avatar
I did the same using a fine roloc scotch brite pad in my angle die-grinder. Provide a good radius there. You can also round over the sharp edge where the valve pocket hits the center of the piston crown. John has some great pictures in his thread.
Old 01-19-2009, 07:52 AM
jimbauman's Avatar
Thanks for the replies - and those are some excellent pix in the slugs thread!
JB
Old 01-19-2009, 08:22 AM
abit off center
cgarr's Avatar
So what are you building??
______________________
Craig
G2Performance
Old 01-19-2009, 08:37 AM
jimbauman's Avatar
..helping a friend rebuild a stock 3.2 into a 3.4. Old cylinders were alusils so he decided to upgrade rather than have them reworked.
JB
Old 01-19-2009, 08:40 AM
abit off center
cgarr's Avatar
Nice: Those looked a lot like the pistons I used in my 3.4 build: Going 10.5/1? twinplug?
Craig
G2Performance
Old 01-19-2009, 08:57 AM
jimbauman's Avatar
Unfortunately not! :-( It has to remain smoggable for California emissions, so the only other mods he can really get away with are 964 cams, SSIs (replaceable at smog time), and a Wong chip.
JB
Old 01-19-2009, 09:04 AM
