Direct injection technology?
I've always liked MFI but never liked its fuel consumption. Motronic or EFI isn't direct injection and never produced power like MFI, so what about the latest technology - Gasoline Direct Injection, such as Siemens Piezo?
http://www.siemensvdo.com.au/press/releases/products/2006/piezo_injection.htm
Could this be better than MFI?
Old 11-09-2006, 09:56 AM
gestalt1's Avatar
i wonder if they make an injector that screws directly into a sparkplug hole. you could twin-plug the heads and use one plug hole for the injector.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 11-09-2006, 02:59 PM
Super Moderator
cstreit's Avatar
And no more deposits on your intake valves as an added benefit!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-09-2006, 09:55 PM
jluetjen's Avatar
Re: Direct injection technology?
What's not to like about MFI fuel consumption? I get 20 MPG out of my 2.0E day after day. It's definitely better then carbs.
As far as Piezo style direct injectors, that's what the Audi R8's and R10's use for their direct injection systems. It's hardly just a bolt-on improvement. My understanding is that the combustion chambers need to be designed to take advantage of the direct injection, as well as a sophisticated engine management system and a high-pressure injection system. Basically, in order to get the mileage improvement, you need to design the motor pretty much from the get-go as a DI engine. It does allow some neat benefits, such as I seem to remember Dorsey Schrader once saying that when the R8 engines were restarted after a pit-stop, that the direct injection system practically allowed them to start without the starter, just by injecting fuel into the compressed cylinder, and lighting it off.
As far as the 911 is concerned, it's not clear to me how you'd be able to get much benefit out of Piezo injectors.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 11-10-2006, 12:41 PM
The direct injection I have seen drawings of (gas engines) has shown the fuel injected into the cylinder.....through the cylinder wall at some point in the compression stroke.
Granted, this was some time back .... the advantages were primairly due to the evaporation process cooling the cylinder and providing a homogeneous mixture at the ignition point.
These were MFI systems.
JPIII
Early Boxster
Old 11-11-2006, 07:51 AM
jluetjen's Avatar
JPIII, are you talking about the old Mercedes Benz system that was used in their race cars?
John
'69 911E
Old 11-11-2006, 04:28 PM
Yes, their F1 car from the 50s.....W196 IIRC.
I dunno if their DB601 from WWII was direct injected, but it was MFI
JPIII
Early Boxster
Old 11-11-2006, 08:48 PM
beepbeep's Avatar
Hmm...why do you say that EFI "never produced the power like MFI"??
If that was the case, wouldn't we still use MFI in F1 cars and the like?
In reality, MFI is not the ultimate injection system many afficionados would like it to be. Arguably, EFI is same thing as MFI. Only difference is that it doesn't wear out and that fuel pressure is somewhat lower. There is a cult of "higher pressure gives better atomization" -followers that believe that there are drastic differencies in power. In reality, difference is negliable and EFI's fine tuning possibilities and absence of wear compensate more than enough.
Thank you for your time,
Old 11-12-2006, 02:47 PM
Re: Re: Direct injection technology?
Thanks all.
I had a '72 2.4S and it drank like fish.
I will send an email to Siemens soon and ask for advice.
Wooo that's even better throttle response than MFI..
Old 11-14-2006, 07:26 AM
tadd's Avatar
Propane holy grail?
This would be like the holy grail for liquid propane injection. The fly in the ointment is the 'largish' vapor pressure of propane at 'hotter' temperatures. Splits regular injectors wide open (350 psi to be safe). Some people are playing with the diesel EFI injectors, but this would be so much better.
tadd
1967 912 with centerlocks… 10 years and still in pieces!
Old 11-14-2006, 08:31 AM
911 tweaks's Avatar
bump...any update??
I live for 911 tweaks...
Old 01-02-2007, 02:03 PM
