Roslin's Avatar
Question Rod bolt torque 9 and 10mm
In wayne's book i found the torque setting for rod bolts : 20 NM and 90 deg. Nothing says if it is for 9 or 10mm bolts..
Is this the correct value for 10mm OEM bolts ?
Roslin
Porsche 911 SC 3.0
Old 11-13-2006, 01:41 PM
Try not, Do or Do not
Henry Schmidt's Avatar
50-55nm for 10mm bolts.
Porsche didn't specify a torque angle until the 9mm bolts used on 930 and Carrera rods..
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-13-2006, 05:04 PM
