I believe you could do that Jason, but you would have to order the entire assembly for each hose, and the rubber hose is only a small part of the cost of manufacturing such an assembly. In your case, it looks like the assembly would include both fuel rails, just as an example.
John,
Have you considered replacing the Porsche fuel line with AN and using adaptor fittings? I did such a thing in my old 3.2. Earl's sells a bunch of AN to metric adaptor fittings. It probalby wouldn't go with your theme, though of complete OEM parts. Also, I worked well with Len from www.Autosportengineering.com in Mass. He's a Porsche guy and has run a shop for 30 years. Len has metric swaging dies and buys bulk German hoses and fabs up replacement lines for various applications I used him for my fuel line in the 3.6 conversion (I have the factory 993 rails and hoses), but also some soft oil lines. You might contact him to see if he can help? Good luck, Doug
1971 RSR - interpretation |
Thanks for the information Doug. I plan to contact them, for hope
springs eternal. Yes I certainly have considered using AN fittings and switching to braided stainless hose, and would do that before I replaced all the metal lines and assemblies. I like especially the fittings from Earl’s which are available in black color. It just all seems out of place in this otherwise OEM car. Actually I wouldn’t be giving it a second thought were it not for the experience of Jason, and the doubts that failure has cast on the SAE hose. Motronic fuel injection runs at about 55 pounds max pressure and there are thousands of cars running around, with all sorts of injection hoses in use. Neither is it anything new……this car is 17 years old! So I am more than a little surprised to find that the correct hose is this difficult to source. But so far, the nearest thing I have found is SAE hose. James |
I like your attitude!
Here's another thought, since you may consider the AN route. check out www.batinc.com . They sell metric fittings, but with AN hose ends, all in one. You don't need an additional AN adaptor to metric fitting. The fitting side of the hose end is threaded in metric. They are no different in cost to Earl's ends, either. I think this may be a viable option for you, too. Good luck, Doug
There must be a typo in the above post. batinc.com sells transformers,
power supplies and other electrical equipment?? |
Doug,
Thanks for that site. Several ways to solve the issue can be found there. Before choosing to use AN fittings, there looks to a better quality push-on hose available. Jason, Perhaps the most important finding on the above site is listed under the MOCAL heading for fluid hoses. Look for Elastomer Socketless hose and we seem to have found another possibility, and very interesting indeed. AEROQUIP 332 PUSH-ON hose looks promising, for using our old fittings. Tomorrow I am going to check with the local Aeroquip shop and see whether it is in stock. If not I will order some from the above site. This may be the answer. |
Well, today I did go over and get samples of the Aeroquip push-
on style hose. It certainly is good quality, but the outer cover is fabric rather than synthetic rubber. The real problem is that this hose is NOT available in 5/16 inch – therefore of no help to us on the 964 fuel injection lines. I did have a productive talk with the hose experts there though, and we all agreed that the SAE J30R9 hose (which I already have in place) is superior to the other options we have been discussing. Jason, I also took off one of my hose sections to check it, because you reported that you easily pulled the same hose off your fuel rail barbs. I could not move that hose at all, and wouldn’t have been able were my life depending on it. So, I still cannot imagine anything other than a size difference. Either the barbs are smaller on the 993, or perhaps you ended up with 3/8 inch hose somehow. Honestly, this stuff is tight and there is not a hint of a leak in any of the fittings. Back to the finish-up on the front struts, which require a wheel alignment whenever they are replaced. That because the Camber adjustment is made at those two lower attachment bolts. The car sets too close to the ground to easily do alignment adjustments without placing the car up on a lift. This photo illustrates that what one must achieve is zero camber on the front wheels. That is they must be vertical when unloaded. Here I have them on turn plates which allow the wheels to settle on a bed of balls located between the two plates. Otherwise, one could move the car back and fort to settle the wheels after each jacking up. Here I note how far off the camber is in terms of bubble position. Then take off the wheel for access to the adjusting bolts and make the needed change by reference to a hub mounted bubble gauge. It takes three off-and-on exercises with the wheels, but soon they are both at zero camber, as needed. Toe-in was checked next and found to be right on the money. Then while at it, I checked the rear settings and found excessive toe-in there. Haven’t figured a way to set the rears without a lift, so that job will go out. I got the primary distributor coil replaced, and now all plugs are firing as they should. If ever you do this job, you will find that it is first necessary to remove a heat-sink plate, after first taking off the two ignition switching units seen here. The manual will advise that the switching units must be coated on the heat sink side with a Bosch temperature conducting paste. Good luck finding it! An alternative is available from Radio Shack, and seen here in the small tube. It is called “heat sink grease”. With the plugs all firing, the engine running smoothly and no drops of any fluid to be seen………..tomorrow will be the road test.
What will be your run-in procedure?
I ran mine up and down hills pretty hard after initial warm-up.
steve old rocket inguneer |
Steve,
My personal run-in procedure does depend upon the engine type. This is a fairly modern example, and so (at least in my own mind) not so critical, as to run-in (where the rings are concerned). I have standard (not synthetic) 10-30 oil in the system for break-in. The plan is to take it out on an unrestricted road and run the car for about 30 minutes at what I consider to be normal RPM; say about 3000. Then I will take advantage of the open, empty, Nevada highway. The plan will be first to pull over and make another check for fluid leaks. That done, I shall go through probably 25-35 cycles of full throttle to 100 MPH then coasting back to 40 or so; then open throttle again, over and over again under full load. Get it hot, then give it hell! That is the road test plan. After that, I shall put it up on stands again for for additional drip testing, probably for about a week. So far –So good, but I do not wish to go forward with even the slighest leak, anywhere. After a week, without a drop anywhere, well maybe it is OK! If all is well, I will go for about 500 miles before the first oil change/inspection, and valve adjustment, with all the mileage done at highway speeds. When the first oil filter is inspected, I expect to find a metal-flake luster, visible only in outside light, it indicates that all is well. If I remember, I shall try to capture it in a photo. But I don’t know whether such detail is within my ability…photography is not my hobby. Split a can on a new engine run, and you will know what is expected. After that first change, the oil should be clean and pure. With this specimen………….well, we shall see. Last edited by JWPATE; 02-14-2007 at 08:48 PM.. |
James,
Good luck! Hope everything works out to your satisfaction. Doug
It was a great test ride. I took it out for about 1.5 hours, more or
less as I planned it. The engine runs great, and really comes alive when going past 4,000 turns under full throttle. A most enjoyable morning of motoring, which included a stop for emission testing, as the license came due while I had the engine apart. Thanks again to all Pelicans who were kind enough to offer tips and recommendations during this rebuild. I could not be happier with the outcome. James |
HI James glad to hear the road test went OK and the car is performing as you would expect, did the car pass the Co% test OK for the license and did you need to set the addaptions on the engine and gearbox?
regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Hi Mike,
Yes the car passed the emissions inspection as below: HC PPM 2500 RPM.....LIMIT- 220..... READING- 1......RESULT- PASS IDLE RPM......LIMIT- 220......READING- 1......RESULT- PASS CO % 2500 RPM.....LIMIT- 1.2O....READING- 0.00....RESULT- PASS IDLE RPM......LIMIT- 1.20....READING- 0.00....RESULT- PASS I have not altered the settings from before the rebuild. |
That was exactly what I did and then found at my first change. |
Sorry for the error Jason........I ment to write Anthony!
Whatever you do - don't get old. |
This week I am doing the first service on the engine since the
rebuild. It still runs sweet and there have been no issues to resolve. It is at about 2500 miles and therefore due for oil change and valve adjust. I had intended to include a photo of the filter innards to illustrate the metal flake that I expected to be present in the break-in oil, what with with new pistons and cylinders wearing in. I didn’t take the photo because I just couldn’t see any metal in the filter whatsoever. That did surprise and impress me. The only thing I have found to be a problem is the unexpected failure of that set of aftermarket aluminum valve covers on the lower or exhaust valves. They looked great and even had “Made in Germany” cast into the inside surface (certainly they were not made in Europe but in Asia). Anyway the pressure from the normal expansion of standard, black rubber gaskets was too much for the aluminum castings. They cracked and broke away in two places………I didn't suspect anything because the failures were on the upper edge and thus didn't cause noticable oil leaking. This photo illustrates the damage. And here is a somewhat closer look at one of the failures. Needless to say, I am going to scrap them and replace the magnesium original covers.
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Hi Chris,
Yes, the lower valve cover leaks can certainly frustrate. I went over and looked at the Imagine site and their aluminum covers. Do we know of anyone with first hand experience? Their claim that the covers will never leak or warp………..sounds nice, but has any member actually put them to the test? I am also interested in them, but all I have to go on is the company claims. A set of those would cost less than half of a new Porsche set. By the way, EBS also has billet aluminum covers at about that same price as Imagine. For now, I have the originals back on. I seem to remember that only one side was leaking before, so I have reversed the originals to see whether the leak moves over too. I also flattened them both on a glass plate with sand paper. I want to leave the engine under-shield off and watch them closely for a while, before deciding what to do next. |
