-   -   Do I need to install tensioners during dry assembly? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/316000-do-i-need-install-tensioners-during-dry-assembly.html)
rlane 11-19-2006 03:09 PM
as above, finished cam timing and ready to move to piston-valve clearance check. I have mechanical chain tensioners in place from cam timing and I can't see much utility in priming and installing the pressure fed tensioners for the piston-valve clearnace check...they are just gonna have to come back out in a few hours. Am I missing something that would require me to install at this time or can I just leave the mechanicals in place till I tear back down for sealing?
afterburn 549 11-19-2006 05:12 PM
logic dictates tension is tension so ...how could it mater ??
