Do I need to install tensioners during dry assembly?
as above, finished cam timing and ready to move to piston-valve clearance check. I have mechanical chain tensioners in place from cam timing and I can't see much utility in priming and installing the pressure fed tensioners for the piston-valve clearnace check...they are just gonna have to come back out in a few hours. Am I missing something that would require me to install at this time or can I just leave the mechanicals in place till I tear back down for sealing?
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 11-19-2006, 03:09 PM
Air Medal or two
afterburn 549's Avatar
logic dictates tension is tension so ...how could it mater ??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-19-2006, 05:12 PM
