EnlightenedOne's Avatar
Exclamation Oil Bubbles!!!
Every time i check the oil on my 3.0 euro carrera at about 80-95C I get little and big bubbles on dip stick.. and oil looks thin even tho im using 20/50 blend.. mind you oil is somewhat fresh... whats goin on???? also with oil cap off and car running, has a constant light mist or steam of oil comming out... to much blow-by maby? or normal
Old 11-28-2006, 04:27 PM
sww914's Avatar
Do it smell like gas?
Old 11-28-2006, 04:44 PM
gas as in exhaust or fuel and no its hard to smell gas off the oil itself.. smells like oil
Old 11-28-2006, 04:50 PM
Porsche Crest
anybody wanna take a crack at it??
Old 11-29-2006, 08:11 PM
You need to give these guys a little more info. Most of my problems in putting 60,000 miles on in the last three years and doing stuff myself have been solved by going back to whatever I last did and doing it right. Did it 'mist or steam oil' before that last oil change? Is the oil level at the top of the dipstick? How about the gauge? Is it showing full cold and hot? Maybe you've overfilled the oil? Or is the sump plate on backwards interfering with the oil pickup? If a shop did the last change go ask them. Me? I just finished rebuilding my pedal cluster with only three washers left over. Pretty good eh? Though that lock washer is a little bothersome. Ah, I bet it'll come to me. NeneneneNaah.
Old 12-07-2006, 10:53 AM
