(the shotguns)
berettafan's Avatar
Cam ID just by removing valve covers?
Is there a way to actually see the part number on my cams by simply removing a valve cover?
I could swear I was told this is possible but when i looked last night it seems the area of the cam where the number would be stamped is hidden.
Do i just need to shut up and buy a dial gauge/z block?
Old 12-01-2006, 05:46 AM
Super Moderator
cstreit's Avatar
I know on some cam's I've seen an ID number on the shank, but I've never really looked at it... Might be a part number.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-01-2006, 09:14 AM
Re: Cam ID just by removing valve covers?
Erick:
You can see part numbers on the cams but thats no guarantee of what they actually are,...
Since many cams get repaired/reground to different profiles, one really needs to measure lift & duration to be sure.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-01-2006, 09:46 AM
(the shotguns)
berettafan's Avatar
but how do i see it? all i can see is the lobes, not the straight part that would have the stamp.
Old 12-01-2006, 11:04 AM
Porsche casts the numbers between the lobes so one usually needs to rotate the engine to see them. The last two numbers are the key ones and they are visible.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-01-2006, 11:12 AM
(the shotguns)
berettafan's Avatar
Thanks again Steve. Will i be getting a bill for all this help?
Honestly i feel like i should put a great big list of thank you's when i do local car shows.
Old 12-01-2006, 11:55 AM
Not a chance,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-01-2006, 11:39 PM
