Weber rebuild:: gasket adhesive
I am rebuilding a pair of 40 IDA 3C carburetors. What adhesive is normally used on the gaskets ---- hardening, non-hardening? Wayne's 101 Projects book does not cover this.
Thanks,
Rick
Old 12-03-2006, 06:55 AM
andrew15's Avatar
No sealant on the Weber carbs - too much of a risk plugging small fuel channels.
- The copper / aluminum gaskets are sealing rings and do just fine on their own
- The top gasket compresses enough to prevent leaking and should not be in constant contact with fuel
- Accelerator pump on side I think uses a rubber / plastic gasket - again, no sealant.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 12-03-2006, 08:48 AM
That explains why I could not find any reference to which sealant to use. Thanks a heap, Andrew!
Best,
Rick
Old 12-03-2006, 09:50 AM
