CMDR Perry's Avatar
Porsche Crest 911 top end rebuild query
Wayne, my 79 911SC has just 69,000 miles and good oil pressure. Next spring I plan to do a top end rebuild and bump the compression up to 9.5:1. Should I inspect/replace the rod bearings? What Octane fuel will I need to use to avoid detonation with the CR bump? Should I consider switching to PMO carbs for better power and throttle response? The car is only driven weekends and auto-crossed. Track events are possible in the future. Thank you.
1986 Mazda Rx-Vetten LS1 swap street / track car
2007 MX-5 Roadster, Cinnamon, MC STR champion (sold)
2013 Scion FR-S, MC STX champion (sold)
2002 Roush Stage 2 (traded)
1979 GP White 911SC coupe, aka "Bruce
Old 12-09-2006, 06:52 AM
sww914's Avatar
I'm not an expert, but from everything I've seen here and inside of 3.0's with that few miles, everything is probably still perfect in there. Plus, a tight top end and a loose bottom end = free HP.
Old 12-10-2006, 04:33 PM
