Rocker side-2-side spec
What is the spec for the side-to-side play for the rocker to cam tower? If over spec, what can you do?
anybody?
Page 207 in Wayne's book (if you promise to buy one for yourself):
Rocker Arm Axial Play: 0.100 to 0.350. Wear limit 0.50. That would be in mm. Limit would be about 20 thou in inches. I know of nothing that has been done about this. I have supposed that you could make the bushings a bit wider. For that matter, you could make thin washers. Most, I think, just ignore it. I've never checked it when rebuilding my engines. Perhaps foolishly, but I can't say I have seen anything obviously prematurely bad as a result. But maybe one of the professional engine builders will rise to the bait and give a better educated view. Walt |
Thanks Walt.
Looks like I have some at the wear limit. Thought about the thin spacer idea, but wondered about where to get them. |
| All times are GMT -8. The time now is 07:50 AM. |
