Forced Induction Junkie
WERK I's Avatar
Rocker side-2-side spec
What is the spec for the side-to-side play for the rocker to cam tower? If over spec, what can you do?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-07-2006, 08:17 AM
WERK I's Avatar
anybody?
Dave
Old 12-08-2006, 07:44 AM
Walt Fricke's Avatar
Porsche Crest
Page 207 in Wayne's book (if you promise to buy one for yourself):
Rocker Arm Axial Play: 0.100 to 0.350. Wear limit 0.50.
That would be in mm. Limit would be about 20 thou in inches.
I know of nothing that has been done about this. I have supposed that you could make the bushings a bit wider. For that matter, you could make thin washers.
Most, I think, just ignore it. I've never checked it when rebuilding my engines. Perhaps foolishly, but I can't say I have seen anything obviously prematurely bad as a result.
But maybe one of the professional engine builders will rise to the bait and give a better educated view.
Walt
Old 12-08-2006, 08:35 PM
WERK I's Avatar
Thanks Walt.
Looks like I have some at the wear limit. Thought about the thin spacer idea, but wondered about where to get them.
Dave
Old 12-10-2006, 07:07 AM
