-   -   Help with P+C choice (http://forums.pelicanparts.com/911-engine-rebuilding-forum/320481-help-p-c-choice.html)
drsimonwong 12-17-2006 02:18 AM
Well my engine stripdown has revealed problem after problem....and my hip pocket is bleeding out.
Amongst too many other things, how to deal with piston and cylinder rebuild/replacement.
I have a Euro 3.2 that has had both low octane fuel and bad oil so the pistons and the Nikasil walls are both shot.
Options are:
Bore out to 3.4, replate and JE pistons. $2000
Supertec QSC 3.4 and JE pistons. $2400
Mahle Euro 3.2 set $3000 (but may be able to get set for $2200-2500)
Perfect Bore 3.4 and JE pistons $3000
Realistically keeping my own Mahle's is the most affordable and favoured option but how good is a "rebulid" vs the other 3 new options?
Help!
Simon
