Value of engine apart?
Question for you engine gurus. Someone is interested in my engine that took a piston hit. My mechanic thinks the crank would be alright and the piston and maybe a rod would be the worst of the engine mishap.
Is this a fair price? 3.0 engine $1000 if crank is damaged $1500 is crank is ok this would be a long block engine which has carrera fed tensioners and turbo valve covers. trying to get a fair price
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 Last edited by FenderGuy; 01-02-2007 at 01:47 PM.. |
is this the 3.0? I would be interested in at your prices.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jeff
I am asking if the price is fair? I feel like its under when I price compontents apart, prices are depend whos buying Case $500 to $1500 Crank $650 to $1000 Carrera Fed Tensioners $350 used Turbo Valve covers $75 to $100 5 Pistons $400? I am trying to get a fair price for items without ripping someone off. My mechanic knows someone who wants my engine, but I feel like the one being taken at the above prices as I think about it.
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 Last edited by FenderGuy; 01-02-2007 at 01:56 PM.. |
The price is low, no question. I would think a 3.0 core is worth at least 2k. Depending on the buyer maybe more.
Figure 1000 for the case 400 min for the heads 150 for cam tower 75 for core cams 50ish for the valve covers 100 oil cooler Tensioners 250-300 crank 650-750 (if standard/standard) rods 100 Rocker arms 50 oil pump ? The above are what I see and have paid/sold as minimum prices for these parts. Could get a lot more for some of them. Now, is it a long block or complete? Because there is fan and housing, alternator, shroud, intake, airbox, WUR etc. It is a give away at 1500 for sure. The pistons could go either way. 5 pistons are hard to sell and it all depends on how they measure out. Is the 6th one junk for sure? Hope that helps a little? Cheers
Jeff
6th is junk as it came out when they drained the oil
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Yikes!
I still think your mechanic is hosing you, but just my opinion. I know I would pay more than 1500 for it. Cheers
