SP2 SP2 is offline
SP2's Avatar
Chain Housing to Crankcase washers
Question: I am replacing my chain housing back on to my crankcase (81SC). There are 2 nuts inside the housing and 3 nyloc nut outside the housing. All five have really skinny washers associated with them. Are the washers reusable? Especially the ones on the inside of the housing, I didn't know if they serve a sealing purpose.
Thanks,
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 01-03-2007, 08:07 PM
The two inside the case have the flat spring washers, same washers as the cam tower to heads. The external nuts have the aluminium washers same as the case perimeter.
For the inside washers, if they are looking flat then the spring has gone.
Paul
Old 01-03-2007, 10:32 PM
SP2 SP2 is offline
SP2's Avatar
Thanks Paul. Yes, my two inside are either flat, or the wrong ones were installed by the PO previously. I'll just replace all the washers.
James
1981 911SC Wine Red
Old 01-03-2007, 10:42 PM
