Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
suggested cam timing and why
I will be timing may cams on my 3.2 ss turbo motor here in the next day or so and wanted to take a poll of what specs you guys would suggest. I could go stock as these are SC cams and this is an sc engine with 8.5-1 JE pistons flat top turbo pistons.. What benifits would I have of your suggestions. I am not looking for anything past 6800 RPM so thats not a concern.. thanks for your time.. Oh this is a 12 plug EFI set up if you guys care and looking for the quickest spool ..
Ben
Custom Welding repair/ Fab service, SS, 4130, TI, Brass, Mag 90 964 (sold)77 911 Turbo conv (sold) 75 914-6 conv (sold) 74 911 Targa (sold) 70 914-4 (sold)
Old 01-03-2007, 06:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Jeff Alton's Avatar
Why would you use other than the stock settings?
Cheers
jeff@turn3autosport.com
Old 01-03-2007, 07:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
I mean low end or high end of the tolerance as some say earlier boost versus later. I was more curious then anything. I am not taking it as word
Ben
Old 01-04-2007, 08:01 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
I don't know about what is best for the turbo motor you're building but I've found that on the normally asperated engines an advanced cam seems to give better overall results. The loss of power above 6500 RPM is much less noticable than the gain at the low end 3000-4500 RPM. I suspect it will be the same for your engine. In addition an advanced cam will help at the lower RPM before the turbo spools up. I'd set 1.7mm on the overlap. This is the most advanced setting of the 3 different factory ranges on these cams. I use 1.4mm on my race car but I spin it to 7200 RPM and have carbs.
-Andy
Old 01-04-2007, 12:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
camgrinder's Avatar
1.4 - 1.7 mm is the best all around setting for the SC cam in a turbo engine. With 8.5-1 compression, you might retard the cams to .9-1.1 mm, depending on your turbo and expected boost psi.
John Dougherty
Dougherty Racing Cams
Old 01-04-2007, 02:19 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
