Distributor Plug where to get/what r we using?
Where are you guys getting your distributor plugs? Are you buying or making? Do you run an o-ring seal?
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Super Moderator
Clewett engineering has them O.T.S. Though they are easy to make with a lathe and a welder. Turn a plug down, cut a groove into it for the o-ring, then weld on a bit to the top to bolt to the former distributor adjustment screw...
I get mine from goingsuperfast.com. It looks just like the Clewett one but is a little less expensive. Takes a factory distributor seal (which I have here). I guess you could seal it with Threebond 1211 or a similar compound as well.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks guys,
Those are two places that both came to mind. I was placing an order with Pelican and couldn't find anything listed here even though they are now carrying some Clewett products. I didn't find the part listed on either site, so I'll just have to call them. Thanks... Chris, the best I could do is Plasma, grinder and weld, it may look better to buy this time. I like to play body shop fabricator, but don't have a true mill or lathe YET!
Richard Clewett made me a custom set of wires and did and awesome job.
1985.5 944 GTS |
Thanks, John...I'll have to figure out where I'm putting coils first and then give him a call. This is obviously not for the engine that someone so graciously shipped me TODAY
I am using Richard for my wires too, and some other odds and ends I needed. This how/where I mounted my coils....
Cheers
