Send a message via AIM to jstein
Angry Arrrg- buggered the spigot surface removing studs
I was removing the last stud on the case to replace with steel and wasn't paying enough attention. The removal tool gouged into the spigot surface where the case meets the cylinder; Maximum depth is about 0.02" towards the center of the cylinder. You can see the build up of the Al from the gouge.
Options?
Here's a disgusting picture
1/5 '86 e30 "SHART" - 24hrs of Lemons veteran
'79 911 SC, webers, blah blah blah - The blue car (FOR SALE)
Old 01-13-2007, 11:25 AM
neilca's Avatar
I see two options. First you can have the block decked, don't forget the cam chain boxes will need to be decked at the same time. Second, fill the divot with Devcon. This is a two part aluminum filled epoxy. Aircraft Spruce carries it. Once cured file to flat. Either way will work.
Good luck,
neil
Old 01-13-2007, 02:55 PM
Devcon seems to be a brand name for a variety of products - I found an Aluminum Putty which may work?:
Aluminum Putty (F)
Aluminum-filled epoxy putty for dependable non-rusting repairs to aluminum castings, machinery and equipment widely used in HVAC applications.
Old 01-13-2007, 03:21 PM
happens all the time. J-B weld and file flat. jaguar even uses it for head dings.
206 637 4071
Old 01-13-2007, 07:50 PM
neilca's Avatar
That is the stuff. John Walker says JB Weld will work. I would use that it, is easier to get and cheaper. I am all about cheaper!
neil
Old 01-14-2007, 09:03 AM
Thanks for the help you guys - I did the repair this weekend and wrote up a little synopsis:
http://gruppeb.org/forum/viewtopic.php?t=4174
Old 01-21-2007, 02:25 PM
neilca's Avatar
It's like a get out of jail free card!
Old 01-21-2007, 04:34 PM
