WydRyd's Avatar
Question Electrosil Cylinder coatings?
Has anyone here had any experience with Electrosil cylinder coatings?
Vendor Write-up:-
Electrosil is the name given to an advanced chemical process that has been developed over the last several years by LM Electroplating Industries. All modern aluminium cylinder bores utilize an electroplated coating to enhance wear characteristics and to provide high temperature heat resistance and heat transfer for continuous service.
The Electrosil coating enables worn and damaged (Nikasil/Electrofusion) cylinder bores to be re-coated to extremely precise bore dimensions and surface hardness. Generally most cylinders have a 0.004" to 0.006" cylinder coating. We are able to re-coat cylinders to manufacturers standard sizes or to an oversize alternative.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-15-2007, 10:08 PM
