304065's Avatar
Photo of 84mm Mahle NIKASIL wanted
Here's a long shot question but worth a try. . . would anyone be kind enough to post a photo of an 84mm Mahle NIKASIL cylinder?
The Biral 84's have a groove in the cylinder to facilitate expansion. I'm curious whether Mahle, when they made all-aluminum 84mm cylinders, such as those sold by Pelican, included this groove, or whether the fins were continuous like the Nikasil cylinders on the 2,7 and later engines. My guess is that they made the fins continuous but would be very interested to see an actual photo.
Wayne, any chance you have a set in stock and could snap a photo of one of the cylinders?
Thanks in advance.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-17-2007, 11:04 AM
304065's Avatar
All right, I realize these are rare. Here are some photos from the Pelican Catalog- - - the pistons certainly resemble the stock pistons, so I assume that there is no break in the fins.
130 HP 80mm 2,0 Normal
160 HP 80mm 2,0 S-- note "S" piston in the bore
180 HP 84mm 2,2 S - note "S" piston in the bore
190 HP 84mm 2,4 S - note "S" piston which isn't as tall, this would reflect the lower compression of the 2,4 piston
These are definitely aluminum cylinders and are fully finned like a 906 cylinder. I think this answers the question.
'81 R65
Old 01-18-2007, 11:43 AM
304065's Avatar
Compare this to Birol cylinders.
'81 R65
Old 01-18-2007, 11:47 AM
John
Here's some pics of a 2.2E set I have. Let me know if you see what you're looking for. If needed I can shoot more pics.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-18-2007, 06:07 PM
304065's Avatar
Tom, thanks for the detailed photos. There is definitely a clear difference between a Mahle Nikasil cylinder and a Birol-- perhaps Mahle put the break in the fins to account for the differential expansion rates of the aluminum and cast iron. Birols are known for significant ovality under stress, perhaps this is the reason why.
Thanks again for taking the time to post.
'81 R65
Old 01-19-2007, 07:05 AM
