-   -   Advice! #1 Spark Plug wet/oily! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/326231-advice-1-spark-plug-wet-oily.html)
JMA-RUF 01-22-2007 04:59 AM
Hopefully you engine building gurus can answer this for me :(
I pulled all my plugs today and found my #1 plug is wetter than the others.
They are all quite sooty, but look dry. #1 however, looks wet, possibly due to excess fuel, or possibly oily residue :(
Does this mean worn valve guides or piston rings? :(
If a compression test/leakdown shows this cylinder is on it's way out, am I looking at BIG $$$$ to do this one P&C?
Engine was rebuilt completely about 2 years ago :mad:
Advice appreciated.
Steve@Rennsport 01-22-2007 10:21 AM
James:
Its time to perform a leakdown test to see what you have going on.
The results will frame what your next step will be.
