84 Carrera Crankshaft 2-Row Pulley, Where is Z1?
Hi everyone,
My crankshaft pulley has several marks on both rows and I don't recall which one is Z1. There are no characters identifying which is what. On the inner pulley nearest the crankshaft there are a total of four marks that appear to be factory stamped. Two of them are about 20 degrees apart from each other and the other are much further away. Can someone please clarify where to look and tell me what all the marks are for. I am currently going through my pre-assembly check for piston to valve clearance. Pictures would be appreciated.
Thanks for your support!
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-04-2007, 12:49 PM
Czar of C.R.A.P.
dfink's Avatar
Where the 2 marks are together Z1 is one on the left or the second mark as you rotate the crank. The other marks are 120* ea.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 02-04-2007, 05:12 PM
Z1 is the mark to the left.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 02-04-2007, 05:48 PM
Thank you both very much! I greatly appreciate it, I can now continue with my project. Great picture!
Best Regards,
Alex
Old 02-04-2007, 06:24 PM
