930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
dull knocking noise at hot idle?
1980 930 turbo
I have a dull knocking noise at hot idle is this normal? Is this the air pump? It does not do this when first started. Oil level is on the money and looks fairly new. Car runs great too. If any1 has any answers let me know.
Pete
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-03-2007, 01:34 PM
Super Moderator
cstreit's Avatar
How is your oil-pressure?
Can you locate an general area for the noise?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-03-2007, 03:16 PM
h20cooled7's Avatar
i want to say the left bank where the air pump is ,if the belt is to loose will it make this noise?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-03-2007, 03:20 PM
h20cooled7's Avatar
acually i here it thru the exhaust on the left and right banks is this just the valves opening and closing ? can i go by the druck pressure?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-03-2007, 03:43 PM
h20cooled7's Avatar
the valve train is noisier on the left side, cna i get away with a volve adjustment ,im wondering if its the type of muffler i have thats making this noise.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-03-2007, 04:04 PM
Send a message via Yahoo to Lukesportsman
Devils advocate:
*Why would a muffler be temp dependent?
*Most valve train noise isn't described as dull knocking, but more ticking unless you have somthing really loose (read maybe broke).
*Is it rpm related?
*Does it go away as the oil pressure builds?
*Do you have a mechanics stethoscope? Sometimes a wood dowel works to narrow source of noise.
*Why not just remove belt to air pump and see if noise changes
Good luck and we all know what we don't want it to be.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-04-2007, 06:59 AM
h20cooled7's Avatar
i tried the stethoscope trick and cannot isolate it. it is not a metalic noise but the left bank is louder than the right .i can only hear it right out of the tail pipe. it sounds like if you had the the head off and were opening and closing the valve manualy ,its a real hollow sound.i talked to the original owner and its due for an adjustment. ill start there.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-04-2007, 07:09 AM
Forced Induction Junkie
WERK I's Avatar
Had the same sounding noise on my 930. Sounded good on cold startup. Then after running for several minutes under load andf then back to idle, the noise was there. Diagnosis: clogged spray bar on cylinder #6. Dry rockers will knock instead of click when there's no oil.
Another area to look at is the alternator. They will actually knock a little when the bearings go on them.
Good luck
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-04-2007, 07:12 AM
h20cooled7's Avatar
if i do find a clogged spraybar on the left bank how do i clean it out?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-04-2007, 09:39 AM
WERK I's Avatar
you'll have to inspect the lobes of the cam to see if that is the case. Remove both the valve covers and use a small mirror to inspect the lobes. Naturally, the lobes will show the greatest damage where the loading on the lobes is the greatest.
To clean the spray bars, you must remove the engine to to get to the cam towers. They come out from the rear of the engine(towards the front of the car).
If the noise is coming from the alternator, drive the car for awhile, pull the fan belt, start the engine and see if the noise has disappeared.
Dave
Old 02-04-2007, 02:36 PM
h20cooled7's Avatar
got ya , ill try the alt trick first
thank you
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 02-04-2007, 02:55 PM
Scott R's Avatar
Good luck
Same noise for me as well, clogged spay bar #6 and #5, cam ended up looking like worm wood. I'm just finishing up my rebuild becuase of this, in fact I removed the old spary bars last night, and let me tell you that was not fun.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-05-2007, 02:03 PM
