Compression on a 930?
What is a good compression to do on a 3.4 turbo engine? I was thinking 7:5:1, what do you guys think?
will also have upgraded exhaust, intercooler, twin plugged, and turbo (probably k27 HF)
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 02-28-2007, 12:48 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
John, check this out:
930 Twin Turbo 3.4 Project...commencing...
7.5:1 will allow more top-end boost, 8:1 may be a bit better for you on the street--a little quicker off the line/low rpm.
Cheers
Scott Kinder
kindersport @ gmail.com
Old 02-28-2007, 02:28 PM
Thanks Scott
John A.
Old 02-28-2007, 02:31 PM
WydRyd's Avatar
My vote is 7.5:1, which will allow you to run higher boost, than a 8.0:1 configuration and will still allow good streetability with nice aftermarket headers, turbo and exhaust.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-28-2007, 06:08 PM
Thans Merv. From the info I got from Scott I'm thinking I will go 7.5:1. Since I will be twin plugging it will really be closer to 8:1 anyways, and I dont want to have to buy new pistons for when i do decide to race. Also the pistons I'm getting are race pistons.
John A.
Old 03-01-2007, 05:56 AM
