Dadofour's Avatar
Proper Deck Height for Euro P's & C's ?
I am doing my second rebuild. This stime around I am installing Nikasil Euro P&C's They are new Mahles and will be installed on my stock '84 3.2.
Do I use the same 1.25 - 1.5 mm deck height or do I go lower to 1MM or something else entirely different? My heads were slightly decked, so I am concerend that I get the deck height right.
Than
Than
My Track Schedule
1984 911 Viper Green Track Car - Parted out to fund
1993 BMW 325is Spec E36 Race Car
Old 03-30-2007, 07:25 PM
I see no reason to have a deck height different than 1-1.5mm. With the higher compression I'd lean toward the 1.5mm myself but anywhere in there should be ok.
-Andy
Old 03-30-2007, 08:29 PM
I have nearly the same set-up, I just finished that part of reassembly on Saturday. I have a deck height of around 1.40, my heights were decked as well and I ended up using 0.75 mm cylinder base gaskets.
Good luck,
alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-01-2007, 10:50 PM
Dadofour's Avatar
Did you combine a .25 and a .50?
Than
My Track Schedule
Old 04-02-2007, 01:07 PM
Yes, I combined them to give me 0.75mm. I also performed a pre-assembly (Dry) check for piston to valve clearance when I had only 0.25 mm base gaskets. I'm glad I did this because I had contact, this is why I went to 0.75mm. My preassembly saved me a lot of money and time, I may have destroyed my engine if I didn't do this check.
Good luck,
Alex
Old 04-02-2007, 01:46 PM
Dadofour's Avatar
I did the preassembly on my first build as well. My first was a totally stock rebuild. The pre-assembly gave me peace of mind. This time I am not sure what I will find.
Thanks for the feedback.
Than
My Track Schedule
Old 04-02-2007, 02:26 PM
